Solarflow Automation - Error in yaml
Hello everyone,
I copied the following automation from this page and customized it to fit my entities.
alias: SolarFlow Nulleinspeisung adaptiv
triggers:
  - seconds: /3
    trigger: time_pattern
conditions:
  - condition: state
    entity_id: input_boolean.solarflow_nulleinspeisung
    state: "on"
actions:
  - data:
      entity_id: number.solarflow_800_pro_outputlimit
      value: >
        {% set grid = states('sensor.shellypro3em_ac151877a150_power') |
        float(0) %} {% set current =
        states('number.solarflow_800_pro_outputlimit') | float(0) %} {% set
        abs_grid = grid | abs %}
        {% set hysterese = 20 %} {% set min_limit = 0 %} {% set max_limit = 800
        {% if abs_grid <= hysterese %}
          {% set target = current %}
        {% elif abs_grid <= 50 %}
          {% set step = 10 %}
          {% set target = current + (step if grid > 0 else -step) %}
        {% elif abs_grid <= 120 %}
          {% set step = 20 %}
        {% else %}
          {% set target = current + grid %}
        {% endif %}
        {{ [min_limit, [target, max_limit] | min] | max | round(0) }}
    action: number.set_value
mode: single
Unfortunately, when I try to save it (even if I don’t change anything in the automation), I get the following error:
Error parsing YAML: missing comma between flow collection entries (line: 13, column: 10)
Maybe someone has an idea what the problem might be. My knowledge of YAML is unfortunately very limited, if not nonexistent. :disappointed_relieved:
Thanks for your time,
Wolle
Welcome to the Home Assistant Forum!
Try this…
value: >
Thanks for your reply, appreciate this but still no luck.
„ Message malformed: template value should be a string for dictionary value @ data[‘actions’][0][‘data’]“
