SolarForecast ML v3.0.0: Adaptive and Self-Learning for Pinpoint Solar Predictions
:tada: Solar Forecast ML v3.0.0 - Final Release
:dart: Core Features
Intelligent Forecasts
  • :white_check_mark: Forecast for Today & Tomorrow
  • :white_check_mark: Time-based Correction - “Today” reduces during the day
  • :white_check_mark: Intelligent Night Detection - No 0 kWh forecasts
  • :white_check_mark: Hourly Forecasts (optional) for short-term predictions
Machine Learning
  • :brain: Automatic daily learning (23:00)
  • :bar_chart: Day Profile Learning collects hourly data
  • :dart: Accuracy Tracking shows model performance
  • :arrows_counterclockwise: Self-Calibration adapts to your system
  • :chart_with_upwards_trend: 30-Day Profile learns typical yield curve
Config Flow UI
  • :sparkles: No YAML configuration needed!
  • :earth_africa: Multilingual (German & English)
  • :memo: Helpful Descriptions for each sensor
  • :wrench: Reconfigure - Sensors can be changed later
  • :control_knobs: Options Flow - Notifications customizable
Weather Integration
  • :de: DWD (German Weather Service) - Optimized and preferred
  • :earth_africa: Met.no - Norwegian Weather Service
  • :cloud: OpenWeatherMap - Alternative
  • :arrows_counterclockwise: Generic - Works with almost all weather integrations
  • :rocket: Auto-Detection - Automatically detects best forecast method
:bar_chart: Sensors
Sensor What it does
Forecast Today Daily forecast (time-corrected)
Forecast Tomorrow Prediction for next day
Accuracy Model performance in %
Status Integration status & diagnostics
Next Hour Short-term forecast (optional)
Manual Button Forecast on button press
:wrench: Technical Features
Stability
  • :zap: Async I/O - No blocking operations
  • :bug: Race-Condition Fix - Weather loads before Solar-ML (after_dependencies)
  • :lock: Error Handling - Robust error handling
  • :memo: Detailed Logging - Easy debugging
Code Quality
  • :package: Modular Structure - Cleanly organized
  • :dart: Entity Registry - Correct HA integration
  • :floppy_disk: Persistent Data - JSON-based storage
  • :2nd_place_medal: Quality Scale: Silver - High code quality
Performance
  • :rocket: Optimized Updates - Only when necessary
  • :dash: Fast Start - Async Loading
  • :bar_chart: Efficient Data Storage
:gift: Advanced Features
Optional Sensors (improve accuracy):
  • :sunny: Lux Sensor - Brightness in Lux or W/m²
  • :thermometer: Temperature Sensor - Outdoor temperature in °C
  • :dash: Wind Sensor - Wind speed
  • :high_brightness: UV Index - UV radiation (0-11)
  • :bar_chart: Forecast.Solar - Comparison with external forecast
  • :zap: Current Power - For day profile learning
  • :electric_plug: Inverter Monitoring - Detects offline status
Notifications (Optional):
  • :sunrise: Daily Forecast (6:00) - Today & Tomorrow
  • :crescent_moon: Learning Result (23:00) - Shows learning progress
  • :warning: Inverter Warning - Reports offline
  • :white_check_mark: Start Notification - Confirms setup
:chart_with_upwards_trend: Recap (THANKS TO THE BETA TESTERS)
Feature v2.x v3.0.0
Config :x: YAML :white_check_mark: UI (Config Flow)
Today Forecast at 6 AM :x: 0 kWh :white_check_mark: Correct prediction
Time Correction :x: None :white_check_mark: Dynamic
Day Profile :x: None :white_check_mark: 30-Day Learning
Hourly Forecast :x: Basic :white_check_mark: ML-based
Weather Support :warning: Limited :white_check_mark: Universal
Multilingual :x: English only :white_check_mark: DE + EN
Help Texts :x: None :white_check_mark: Detailed
HACS :warning: Manual :white_check_mark: Fully compatible
Error Handling :warning: Basic :white_check_mark: Robust
:package: Installation
Via HACS (Recommended):
  1. HACS → Integrations → ⋮ → Custom Repositories
  2. Add: Zara-Toorox/ha-solar-forecast-ml
  3. Category: Integration
  4. Install “Solar Forecast ML”
  5. Restart Home Assistant
  6. Add integration (UI)
Manual:
  1. Download solar_forecast_ml.zip
  2. Extract to /config/custom_components/
  3. Restart Home Assistant
  4. Add integration (UI)
:books: Documentation
  • :open_book: README: Full instructions
  • :memo: CHANGELOG: All changes
  • :bug: Issues: Report bug
  • :speech_balloon: Discussions: Questions & Ideas
:pray: Thanks
Special thanks to:
  • Home Assistant Community
  • HACS Team
  • All Beta Testers
:dart: Next Steps
After installation:
  1. :alarm_clock: Wait 24h - First data collection
  2. :bar_chart: After 7 days - First accuracy values
  3. :dart: After 30 days - Optimal performance
:star: If you like v3.0.0, give the project a star!
:bug: Problems? → Create an issue
Good luck with v3.0.0! :sun_with_face:
Instaelled without problems. Lets see how accurate it will be.
seems to be an issue with the language
my system language is English but sensor output data are in German
There is nothing quite like reading the documentation.
Entities
The integration creates the following sensors and buttons. (Note: Default entity names are in German as defined in the code; you can rename them in Home Assistant.)
I understand, i said the sensor output is also in German that part I can’t rename.
if that is intended to be also in German then it wlil be difficult for none German audience of you want to attract more international users
Ah yes. That requires template sensors to do the translation ad-hoc.
Perhaps the repo owner, or some kind soul, will add the required translation JSON.
also the notification are in German
Solar-Prognose
Heute: 9.6 kWh, Morgen: 8.3 kWh
:white_check_mark: SolarForecastML gestartet
Basiskapazität: 29.75 kWh
:bulb: Lern-Ergebnis 2025-10-25
Prognose: 9.63, Tatsächlich: 6.60, Abweichung: -45.9%
:brain: Modell hat für 2025-10-25 gelernt
Die Prognoseabweichung betrug -3.03 kWh. Die Gewichte wurden angepasst.
