Solarman Energy Dashboard- How to Split Battery Charge/Discharge Sensor?
Hi there,
New to Home Assistant.
Im looking for some help as im not sure where im going wrong.
The solarman intergration for my Solar only has 1 sensor for battery charge and discharge Positive and negative values
I have setup two template sensors to split it out but the reporting is way higher than expected.
  - sensor:
      state: >-
        {% if states('sensor.solarman_battery_charge_discharge_power') | float
        >= 0 %} {{ states('sensor.solarman_battery_charge_discharge_power') }}
        {% else %}
        {{ 0 }}
        {% endif %}
      state_class: total_increasing
      unit_of_measurement: kWh
      device_class: energy
      unique_id: EnergyToBattery1
  - sensor:
      state: >-
        <= 0 %} {{ states('sensor.solarman_battery_charge_discharge_power') | float | abs }}
        {% else %}
        {{ 0 }}
        {% endif %}
      unique_id: EnergyFromBattery1
Screenshot 2024-02-23 171944
When i look at the sensor via Dev Tools the value being displayed is correct the values are just way to high for the total increasing
