Universal Solar Inverter over Modbus RS485 / TCP custom_component (Growatt, Sofar, SolaX, Solis)
@wills106
Hi Will,
I posted a question on your personal github page, but had no reply so far. So I repeat it here:
Would very much appreciate your help.
I have a new X3 Hybrid 10 kW with 3 x 5.8 kWh Solax Triple Power batteries.
Here in Flanders we will be charged extra when we have a high power consumption, called “capacity tariff”. The distributor measures the consumption per 15 minutes and takes the highest peak of a month to calculate the distribution costs.
To be able to limit power consumption peaks when the battery is empty, I can switch from 12 % min charge to 10 % min charge by writing to holding register 32. So the remaining 2 % become available to the house, lowering the current 15 minute peak value.
However, when the inverter is in “Idle Mode” it takes more than a minute before it starts producing (first performs a 1 minute self check).
Do you know a way to speed up this process? Some register to wake the inverter instantly? Or a way to prevent it from going into “idle mode”?
Also, do you know if the inverter automatically starts charging the battery from the grid if I have used the 2 % and switch the low limit back to 12 %? The operation mode is “Self Use”
Thanks in advance
JP
I have responded on GitHub, I kept meaning to reply but I forgot sorry.
Hi all,
I have a Solax X3 9.0 T D, which is equipped with an RJ45 connector on the “RS485/Meter” port. I tried connecting using a USB-to-RS485 dongle, using the blue wire as A and the blue-white wire as B, however I get no reply from the inverter (0 bytes received, says pymodbus). My questions:
  1. Is the wiring correct? I used the setup described under “Meter” in the manual, but I’m not sure it’s correct and can’t find info on other types of wiring.
  2. Does the interface somehow need to be enabled in the menus of the X3? If so, I have no control over that, it seems.
Thanks,
Bart
Does anyone know what Solax Hybrid X3 run mode ‘11’ means? 2 = normal, 9 = idle, but what is 11?
I made some progress on this using indeed pins 4 and 5 for RS485 comms and lowering the baud rate, but now I get an error that the register addresses are illegal, even though I am using the same numbers as in the X3 yaml config. I am using a USB-to-RS485 dongle with the ch341 chip: Products | Joy-IT
EDIT: This is solved now, see Add support for RS485 Solax X3 by barche · Pull Request #16 · InfernoEmbedded/PowerScraper · GitHub
I think it’s “PV Wake Up Bat” ( source: PV SolaX inverter cloud sensors via API )
@Bart,
thank you for the link. I have been playing around with the “grid tied limit” and noticed that the run mode 11 came on when the battery was on the low limit of 10 %, so “battery awaken” sounds logical.
Hi, I am currently using the solax pocket wifi 2 usb dongle to get the data off my solax inverter, which is not ideal as I have had to set up a dns server to redirect dns request for www.eu.solaxcloud.com and mqtt01/mqtt02.solaxcloud.com to my raspberry pi AP/HA setup, and I then read the mqtt data in HA.
I have also used the curl command, which was more reliable than mqtt, but more work to get it to working within HA.
With mqtt the inverting does reqsynctime and then waits for a respsynctime from solaxcloud, and then sends a Synctime mqtt message when its sync’ed. Because there is no response from my mqtt broker for reqsynctime it sometimes goes off line/hangs with no mqtt messages - this can be for minutes or sometimes hours and then the inverter starts sending data again.
I have found this doc with pocket wifi teardown:
https://fccid.io/2AMEH-POCKETWIFI/Internal-Photos/Internal-Photos-3499969
This is the wifi module they are using:
https://en.mxchip.com/productinfo/244895.html
Has anyone tried to make there own dongle with tasmota to get the data off, then send over mqtt.
Basically I am wanting to have a setup like a sonoff switch with tasmota, easy to configure and use with HA.
I am on my 3rd pocket wifi, one was replaced when the invert failed a few months after install, and a second one failed after a couple of years use - both replaced under warranty which was good except for the 2 weeks wait for replacement to arrive, so looking for something more reliable.
I am wondering if I could use the USB port for power/data to an ESP8266 module, or use a RS485 module to serial UART and connect that to a ESP8266 WIFI with tasmota on it.
Something like this dutch guy has done with his energy meters:
https://diytechandrepairs.nu/esp8266-to-monitor-electricity-with-sdm-devices-and-send-to-mqtt/
Anyone with Solax X1-Hybrid Generation 4? I would like to know If the Modbus RTU works on these new models.
Hello I have recently bought a Solax X1 hybrid, Im looking to connect my own HV battery so i need a capture of the CAN-bus on start-up, is there anyone here that can help? Thanks
Wills, after the update to core-2021.7.3, looks modbus changed, my solax entities stoped to work. I believe i have to change something in the solax.yaml under packages.
Can you point in the right direction?
I have made some changes to the group read for the Solax X3 so that it works with the new home assistant.
modbus:
    type: tcp # Comment out for RS485
    host: "IP nr" # Comment out for RS485
    port: 502 # Comment out for RS485¨
    timeout: 5
    sensors:
  # Holding Registers
      - name: SolaX Group h1
        address: 139
        count: 19
        data_type: custom
        structure: ">19H"
        scan_interval: 3
      - name: SolaX Group h2
        address: 180
        count: 8
        data_type: custom
        structure: ">8H"
        scan_interval: 3
  # Input Registers
      - name: SolaX Group i1
        address: 0
        input_type: input
        count: 30
        data_type: custom
        structure: ">H2h5Hh3Hh7H3hHh5H"
      - name: SolaX Group i2
        address: 70
        input_type: input
        count: 14
        data_type: custom
        structure: ">2h10HI"
    sensors:
# SolaX Group H1
      solax_charger_use_mode:
        friendly_name: "SolaX Charger Use Mode"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[0] }}"
      solax_battery_min_capacity:
        friendly_name: "SolaX Battery Minimum Capacity"
        unit_of_measurement: "%"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[1] }}"
      solax_battery_type:
        friendly_name: "SolaX Battery Type"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[2] }}"
      solax_battery_charge_float_voltage:
        friendly_name: "SolaX Battery Charge Float Voltage"
        unit_of_measurement: V
        value_template: "{{ states('sensor.solax_group_h1').split(',')[3]| float / 10 }}"
      solax_battery_discharge_cut_off_voltage:
        friendly_name: "SolaX Battery Discharge Cut Off Voltage"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[4]| float / 10 }}"
      solax_battery_charge_max_current:
        friendly_name: "SolaX Battery Charge Maximum Current"
        unit_of_measurement: A
        value_template: "{{ states('sensor.solax_group_h1').split(',')[5]| float / 10 }}"
      solax_battery_discharge_max_current:
        friendly_name: "SolaX Battery Discharge Maximum Current"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[6]| float / 10 }}"
      solax_charger_start_time_1:
        friendly_name: "SolaX Charger Start Time 1"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[7] }}:{{ states('sensor.solax_group_h1').split(',')[8] }}"
      solax_charger_end_time_1:
        friendly_name: "SolaX Charger End Time 1"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[9] }}:{{ states('sensor.solax_group_h1').split(',')[10] }}"
      solax_charger_start_time_2:
        friendly_name: "SolaX Charger Start Time 2"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[15] }}:{{ states('sensor.solax_group_h1').split(',')[16] }}"
      solax_charger_end_time_2:
        friendly_name: "SolaX Charger End Time 2"
        value_template: "{{ states('sensor.solax_group_h1').split(',')[17] }}:{{ states('sensor.solax_group_h1').split(',')[18] }}"
# SolaX Group H1
      solax_allow_grid_charge:
        friendly_name: "SolaX Allow Grid Charge"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[0] }}"
      solax_export_control_factory_limit:
        friendly_name: "SolaX Export Control Factory Limit"
        unit_of_measurement: W
        value_template: "{{ states('sensor.solax_group_h2').split(',')[1]| float / 10 }}"
      solax_export_control_user_limit:
        friendly_name: "SolaX Export Control User Limit"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[2]| float / 10 }}"
      solax_eps_mute:
        friendly_name: "SolaX EPS Mute"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[3] }}"
      solax_eps_set_frequency:
        friendly_name: "SolaX EPS Set Frequency"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[4] }}"
      solax_inverter_rate_power:
        friendly_name: "SolaX Inverter rate Power"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[6] }}"
      solax_language:
        friendly_name: "SolaX Language / Sprache"
        value_template: "{{ states('sensor.solax_group_h2').split(',')[7] }}"
# SolaX Group I1
      solax_inverter_voltage:
        friendly_name: "SolaX Inverter Voltage"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[0]| float / 10 }}"
      solax_inverter_current:
        friendly_name: "SolaX Inverter Current"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[1]| float / 10 }}"
      solax_inverter_load:
        friendly_name: "SolaX House Load"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[2] }}"
      solax_pv_voltage_1:
        friendly_name: "SolaX PV Voltage 1"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[3]| float / 10 }}"
      solax_pv_voltage_2:
        friendly_name: "SolaX PV Voltage 2"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[4]| float / 10 }}"
      solax_pv_current_1:
        friendly_name: "SolaX PV Current 1"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[5]| float / 10 }}"
      solax_pv_current_2:
        friendly_name: "SolaX PV Current 2"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[6]| float / 10 }}"
      solax_grid_frequency:
        friendly_name: "SolaX Grid Frequency"
        unit_of_measurement: Hz
        value_template: "{{ states('sensor.solax_group_i1').split(',')[7]| float / 100 }}"
      solax_inverter_temperature:
        friendly_name: "SolaX Inverter Temperature"
        unit_of_measurement: °C
        value_template: "{{ states('sensor.solax_group_i1').split(',')[8] }}"
      solax_run_mode:
        friendly_name: "SolaX Run Mode"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[9] }}"
      solax_pv_power_1:
        friendly_name: "SolaX Power Power 1"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[10] }}"
      solax_pv_power_2:
        friendly_name: "SolaX Power Power 2"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[11] }}"
      solax_time_count_down:
        friendly_name: "SolaX Time Count Down"
        unit_of_measurement: s
        value_template: "{{ states('sensor.solax_group_i1').split(',')[19]| float / 1000 }}"
      solax_battery_voltage_charge:
        friendly_name: "SolaX Battery Voltage"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[20]| float / 10 }}"
      solax_battery_current_charge:
        friendly_name: "SolaX Battery Curent"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[21]| float / 10 }}"
      solax_battery_power_charge:
        friendly_name: "SolaX Battery Power"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[22] }}"
      solax_bms_connect_state:
        friendly_name: "SolaX BMS Connect State"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[23] }}"
      solax_battery_temperature:
        friendly_name: "SolaX Battery Temperature"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[24] }}"
      solax_battery_capacity_charge:
        friendly_name: "SolaX Battery Capacity"
        value_template: "{{ states('sensor.solax_group_i1').split(',')[28] }}"
# SolaX Group I2
      solax_feedin_power:
        friendly_name: "SolaX Measured Power"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[0] }}"
      solax_feedin_energy_total:
        friendly_name: "SolaX Feedin Energy Total"
        unit_of_measurement: kWh
        value_template: "{{ states('sensor.solax_group_i2').split(',')[2]| float / 10 }}"
      solax_consumed_energy_total:
        friendly_name: "SolaX Consumed Energy Total"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[4]| float / 10 }}"
      solax_eps_volatge:
        friendly_name: "SolaX EPS Voltage"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[6]| float / 10 }}"
      solax_eps_current:
        friendly_name: "SolaX EPS Current"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[7]| float / 10 }}"
      solax_eps_power:
        friendly_name: "SolaX EPS Power"
        unit_of_measurement: VA
        value_template: "{{ states('sensor.solax_group_i2').split(',')[8] }}"
      solax_eps_frequency:
        friendly_name: "SolaX EPS Frequency"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[9]| float / 10 }}"
      solax_energy_today:
        friendly_name: "SolaX Today's Yield"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[10]| float / 10 }}"
      solax_total_energy_to_grid:
        friendly_name: "SolaX Total Export"
        value_template: "{{ states('sensor.solax_group_i2').split(',')[12]| float / 1000 }}"
# Combine PV1 and PV2 power
      solax_pv_total_power:
        friendly_name: "Solax PV Total Power"
        value_template: "{{ states('sensor.solax_pv_power_1') | int + states('sensor.solax_pv_power_2') | int }}"
        unit_of_measurement: 'W'
      solax_run_mode_template:
        value_template: >-
          {% if is_state('sensor.solax_run_mode', '0') %}
            Waiting
          {% elif is_state('sensor.solax_run_mode', '1') %}
            Checking
          {% elif is_state('sensor.solax_run_mode', '2') %}
            Normal Mode
          {% elif is_state('sensor.solax_run_mode', '3') %}
            Off Mode
          {% elif is_state('sensor.solax_run_mode', '4') %}
            Pemanent Fault Mode
          {% elif is_state('sensor.solax_run_mode', '5') %}
            Update Mode
          {% elif is_state('sensor.solax_run_mode', '6') %}
            EPS Check Mode
          {% elif is_state('sensor.solax_run_mode', '7') %}
            EPS Mode
          {% elif is_state('sensor.solax_run_mode', '8') %}
            Self Test
          {% elif is_state('sensor.solax_run_mode', '9') %}
            Idle Mode
            Unknown
      solax_charger_use_mode_template:
        value_template: >-
          {% if is_state('sensor.solax_charger_use_mode', '0') %}
            Self Use Mode
          {% elif is_state('sensor.solax_charger_use_mode', '1') %}
            Force Time Use
          {% elif is_state('sensor.solax_charger_use_mode', '2') %}
            Back Up Mode
          {% elif is_state('sensor.solax_charger_use_mode', '3') %}
            Feedin Priority
            Unknown
      solax_bms_connect_state_template:
        value_template: >-
          {% if is_state('sensor.solax_bms_connect_state', '0') %}
            Disconnected
          {% elif is_state('sensor.solax_bms_connect_state', '1') %}
            Connected
            Unknown
      solax_battery_type_template:
        value_template: >-
          {% if is_state('sensor.solax_battery_type', '0') %}
            Lead Acid
          {% elif is_state('sensor.solax_battery_type', '1') %}
            Lithium
            Unknown
      solax_allow_grid_charge_template:
        value_template: >-
          {% if is_state('sensor.solax_allow_grid_charge', '0') %}
            Forbidden
          {% elif is_state('sensor.solax_allow_grid_charge', '1') %}
            Charger Time 1
          {% elif is_state('sensor.solax_allow_grid_charge', '2') %}
            Charger Time 2
          {% elif is_state('sensor.solax_allow_grid_charge', '3') %}
            Both Charger Time's
            Unknown
      solax_eps_mute_template:
        value_template: >-
          {% if is_state('sensor.solax_eps_mute', '0') %}
            Off
          {% elif is_state('sensor.solax_eps_mute', '1') %}
            On
            Unknown
      solax_eps_set_frequency_template:
        value_template: >-
          {% if is_state('sensor.solax_eps_set_frequency', '0') %}
            50Hz
          {% elif is_state('sensor.solax_eps_set_frequency', '1') %}
            60Hz
            Unknown
      solax_language_template:
        value_template: >-
          {% if is_state('sensor.solax_language', '0') %}
            English
          {% elif is_state('sensor.solax_language', '1') %}
            Deutsche
            Unknown
input_boolean:
  solax_backup:
    name: SolaX Backup Mode
  solax_forcetime:
    name: SolaX Force Time
  solax_feedin:
    name: SolaX Feed In
    initial: off
input_number:
  solax_battery_charge:
    name: SolaX Battery Charge A
    min: 0
    max: 25 # Technical Datasheet states Max Charge is 30A, but recommend 25A
    step: 1
  solax_battery_discharge:
    name: SolaX Battery Disharge A
    min: 0
    max: 25 # Technical Datasheet states Max Discharge is 30A, but recommend 25A
    step: 1
  solax_battery_min_energy:
    name: "SolaX Battery Min Energy Level %"
    min: 10 # Technical Datasheet states Max DOD is 90%
    max: 70
    step: 5
  solax_battery_charge_max:
    name: "SolaX Battery Force Charge Capacity"
    min: 20
    max: 95
    step: 5
    initial: 60
automation:
  - alias: House Battery Charge Rate
      platform: state
      entity_id: input_number.solax_battery_charge
    - service: modbus.write_register # Battery Charge
      data_template:
        hub: SolaX
        unit: '255'
        address: '36'
        value: "{{ (trigger.to_state.state | float * 10) | int }}"
    - delay: '00:00:01'
    - service: modbus.write_register # Repeat Battery Charge incase Inverter missed first
      data_template:
        hub: SolaX
        unit: '255'
        address: '36'
  - alias: House Battery Disharge Rate
      platform: state
      entity_id: input_number.solax_battery_discharge
    - service: modbus.write_register # Battery Discharge
      data_template:
        hub: SolaX
        unit: '255'
        address: '37'
    - delay: '00:00:01'
    - service: modbus.write_register # Repeat Battery Discharge incase Inverter missed first
      data_template:
        hub: SolaX
        unit: '255'
        address: '37'
  - alias: "House Battery Min Energy %"
      platform: state
      entity_id: input_number.solax_battery_min_energy
    - service: modbus.write_register # Min Discharge %
      data_template:
        hub: SolaX
        unit: '255'
        address: '32'
        value: "{{ trigger.to_state.state | int }}"
  - alias: Solax Backup
      platform: state
      entity_id: input_boolean.solax_backup
      to: 'on'
    - service: modbus.write_register # Backup mode
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '2'
  - alias: Solax Backup Off
      platform: state
      to: 'off'
    - service: modbus.write_register # Auto Mode
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '0'
  - alias: Solax ForceTime
      platform: state
      entity_id: input_boolean.solax_forcetime
      to: 'on'
    - service: modbus.write_register # Force Time Mode
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '1'
    - delay: '00:00:01'
    - service: modbus.write_register # 2nd Force Time Mode incase Inverter missed first
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '1'
  - alias: Solax ForceTime Off
      platform: state
      to: 'off'
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '0'
    - delay: '00:00:01'
    - service: modbus.write_register # 2nd Auto Mode incase Inverter missed first
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '0'
  - alias: Solax Feed In
      platform: state
      entity_id: input_boolean.solax_feedin
      to: 'on'
    - service: modbus.write_register # Feed In Mode
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '3'
  - alias: Solax Feed In Off
      platform: state
      to: 'off'
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '0'
    - delay: '00:00:01'
      data_template:
        hub: SolaX
        unit: '255'
        address: '31'
        value: '0'
I have updated my GitHub in case you haven’t noticed with the changes for 2021.7.x
Very very early stage of a custom_component
Look at the known issues, it’s more proof of concept at the min.
I don’t plan on adding HACS support yet, so don’t ask.
@wills106 - Looking Good
Screenshot 2021-08-10 at 17.53.37
Just pushed out version 0.0.2
BMS Connect State
Start and End Times for Force-Time-Mode Formatted
House Load Import, Export & Solar Daily Energy working in Energy Dashboard
Optional Sensors on the 4th Tickbox
Edit: 13 Aug 2021
EPIC Version bump!
0.1.0 Just released.
  • Working config screen!
Version 0.2.0
More Optional Sensors
X3 Support
X1 EPS Sensors
X3 EPS Sensors
Version 0.2.1
New Optional Sensors - Only seem to update when Import / Exporting?
  • Consumed Energy Total
  • Feedin Energy Total
Total Energy To Grid - Tweaked to see if it returns sensible figure?
SolaX Today’s Export Energy - Rounded to two places and moved to Gen3 only
Added missing sensors to Gen3 X3
  • Battery Current Charge
  • Battery Voltage Charge
Can I ask what firmware version yr SK-SU5000 is running? Mine is very old so I need to ask Solax for a firmware file for update and a procedure to install.
@robb1
This is the version I have. I managed to get it from another forum as SolaX are useless at support and dont understand why we want the latest version etc
Thanks. Mine is 2 yrs older : SolarSingle&Charger_20140708.
I will try Solax first and then look further if they don’t oblige.
Happy to DM you the links and the F/W
Do so at your own risk as I bricked mine and had to take it apart, connect direct to the board and flash
No big deal just a bit or a brown undies moment :slight_smile:
