Solax_modbus issues
Logger: homeassistant.util.loop
Source: util/loop.py:77
First occurred: 13:08:14 (1 occurrences)
Last logged: 13:08:14
Detected blocking call to import_module with args (‘custom_components.solax_modbus’,) in /usr/src/homeassistant/homeassistant/loader.py, line 1074: ComponentProtocol, importlib.import_module(self.pkg_path) inside the event loop; This is causing stability issues. Please create a bug report at GitHub · Where software is built For developers, please see Blocking operations with asyncio | Home Assistant Developer Docs Traceback (most recent call last): File “”, line 198, in _run_module_as_main File “”, line 88, in _run_code File “/usr/src/homeassistant/homeassistant/main.py”, line 227, in sys.exit(main()) File “/usr/src/homeassistant/homeassistant/main.py”, line 213, in main exit_code = runner.run(runtime_conf) File “/usr/src/homeassistant/homeassistant/runner.py”, line 154, in run return loop.run_until_complete(setup_and_run_hass(runtime_config)) File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 712, in run_until_complete self.run_forever() File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 683, in run_forever self._run_once() File “/usr/local/lib/python3.13/asyncio/base_events.py”, line 2040, in _run_once handle._run() File “/usr/local/lib/python3.13/asyncio/events.py”, line 89, in _run self._context.run(self._callback, *self._args) File “/usr/src/homeassistant/homeassistant/setup.py”, line 171, in async_setup_component result = await _async_setup_component(hass, domain, config) File “/usr/src/homeassistant/homeassistant/setup.py”, line 340, in _async_setup_component component = await integration.async_get_component() File “/usr/src/homeassistant/homeassistant/loader.py”, line 1026, in async_get_component comp = self._get_component() File “/usr/src/homeassistant/homeassistant/loader.py”, line 1074, in _get_component ComponentProtocol, importlib.import_module(self.pkg_path)
