Hello!
I was using the same API as the Home Assistant integration for my own Solax graphing. Handy, simple local API, albeit exposed over an open Wifi access point.
I’ve recently replaced the wifi with a Pocket LAN (mostly because of the flakey, open AP) and while it’s plug & play to SolaxCloud, the IP doesn’t expose port 80 any more
There is an API facility on SolaxCloud (under Service→API) but it’s missing some of the stats I used to graph and “only” updated ever 5 minutes.
I understand the built-in ethernet port exposes a modbus-based interface, but my inverter’s ethernet is connected to the TriplePower battery - is that connection necessary?
Any ideas on how to get the same data back would be much appreciated
