SolaxCloud - RestAPI - configuration.yml Example Template
After along time reading and implementing and testing ended up with this configuration
  - platform: rest
    resource: https://www.solaxcloud.com/proxyApp/proxy/api/getRealtimeInfo.do?tokenId=2XXXXXXXXXXXXXXXXXX&sn=SXXXXXXXXX
    method: GET
    scan_interval: 15
    json_attributes_path: "$.result"
    json_attributes:
      - yieldtoday
      - yieldtotal
      - acpower
      - uploadTime
      - inverterStatus
      - feedinpower
      - feedinenergy
      - consumeenergy
    value_template: "1" # dummy value, not used; avoids the "State max length is 255 characters" error
    sensors:
      solax_x1_yieldtoday:
        friendly_name: "Solax X1 yieldtoday"
        value_template: "{{ state_attr('sensor.solax_x1', 'yieldtoday') }}"
        unit_of_measurement: "kWh"
      solax_x1_consumeenergy:
        friendly_name: "Solax X1 consumeenergy"
        value_template: >-
          {%  if (state_attr('sensor.solax_x1', 'consumeenergy')| float | round(2)) > 0 -%}
            {{ (state_attr('sensor.solax_x1', 'consumeenergy')| float | round(2))}}
          {%- endif %}
        availability_template: >-
          {{ state_attr('sensor.solax_x1', 'consumeenergy') not in ['unknown', 'unavailable', '0', '0.0']}}
      solax_x1_yieldtotal:
        friendly_name: "Solax X1 yieldtotal"
        value_template: >-
          {%  if (state_attr('sensor.solax_x1', 'yieldtotal')| float | round(2)) > 0 -%}
            {{ (state_attr('sensor.solax_x1', 'yieldtotal')| float | round(2))}}
          {%- endif %}
          {{ state_attr('sensor.solax_x1', 'yieldtotal') not in ['unknown', 'unavailable', '0', '0.0']}}
      solax_x1_acpower:
        friendly_name: "Solax X1 acpower"
        value_template: "{{ state_attr('sensor.solax_x1', 'acpower') }}"
        unit_of_measurement: "Wh"
      solax_x1_feedinenergy:
        friendly_name: "Solax X1 feedinenergy"
        value_template: >-
          {%  if (state_attr('sensor.solax_x1', 'feedinenergy')| float | round(2)) > 0 -%}
            {{ (state_attr('sensor.solax_x1', 'feedinenergy')| float | round(2))}}
          {%- endif %}
          {{ state_attr('sensor.solax_x1', 'feedinenergy') not in ['unknown', 'unavailable', '0', '0.0']}}
      solax_x1_feedinpower:
        friendly_name: "Solax X1 feedinpower"
        value_template: "{{ state_attr('sensor.solax_x1', 'feedinpower') }}"
      solax_x1_upload_time:
        friendly_name: "Solax X1 upload time"
        value_template: "{{ state_attr('sensor.solax_x1', 'uploadTime') }}"
      solax_x1_status:
        friendly_name: "Solax X1 status"
        value_template: >
          {% if state_attr('sensor.solax_x1', 'inverterStatus') == '100' %}Wait
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '101' %}Check
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '102' %}Normal
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '103' %}Fault
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '104' %}Permanent Fault
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '105' %}Update
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '106' %}EPS Check
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '107' %}EPS
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '108' %}Self-test
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '109' %}Idle
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '110' %}Standby
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '111' %}Pv Wake Up Bat
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '112' %}Gen Check
          {% elif state_attr('sensor.solax_x1', 'inverterStatus') == '113' %}Gen Run
          {% else %}Offline{% endif %}
to be able to use on energy meter panel this also needs to be applied under homeassistant customization
homeassistant:
  customize:
    #From grid consumption
    sensor.solax_x1_consumeenergy:
      state_class: total_increasing
      device_class: energy
    #Solar Production Today
    sensor.solax_x1_yieldtoday:
    #Total Production Since Reset
    sensor.solax_x1_yieldtotal:
    #grid return
    sensor.solax_x1_feedinenergy:
    #Current Power Grid Injection
    sensor.solax_x1_feedinpower:
      state_class: measurement
      device_class: power
    #Current Solar Production
    sensor.solax_x1_acpower:
      device_class: power
Nice, looks a lot like mine. One difference is that I used the value_template of the rest sensor as an overall health check of the cloud service, and linked all the template sensor availability attributes to that being healthy:
    value_template: >
      {% if value_json.success == true %}OK{% else %}Error: {{ value_json.result }}{% endif %}
Setting the state_class and device_class can also be done directly on the template sensors, no need to use customization for that:
    - name: "X3-MIC daily yield"
      unique_id: "<inverterserialno>-yieldtoday"
      state: "{{ state_attr('sensor.solax_cloud_x3_mic', 'yieldtoday') }}"
      availability: "{{ is_state('sensor.solax_cloud_x3_mic', 'OK') }}"
      unit_of_measurement: kWh
I also added a unique_id to the template sensors so they are more customizable in the frontend.
I do believe you need to use the “new” style template sensors for this.
