Solis modbus integration
Hello, anyone here using this integration? GitHub - Pho3niX90/solis_modbus: Home Assistant HACS integration for Solis inverters
Im not sure if It can read my data, I installed it and after putting some info from the 470 entitis I was able to pull the SOC of battery but nothing else. What can I do to be able to show all data? Any tips?
Thank you
Try the Protocol Wizard and see if it helps with debugging. Have documentation close by.
