Solutions for LPG tank monitoring
No worries! Thanks!
Hopefully you’re well rested :rofl:
I have a couple of the Mopeka units, & like them very much. Accuracy has been very good, when checked against analog tank gauge. Mopeka advertises them as accurate to +/- 1%, They have onboard temperature sensors to compensate for temp/volume changes.
I have Mopeka Pro on 20-lb vertical tanks (on barbecue grill and smoker). Mopeka Pro+ on the 500-gal horizontal bulk tank.
They attach magnetically to bottom of tank, & use ultrasonic (sonar) to find liquid level, Reporting is via long-range Bluetooth.
This is just a prototype. There will be quite a bit to adjust depending on what additional info you include on the card
type: picture-elements
image: /local/pics/bottle2.png
elements:
  - type: custom:fluid-level-background-card
    card:
      type: glance
      show_name: false
      show_icon: false
      show_state: false
      entities:
        - entity: input_number.number
    state_color: false
    fill_entity: input_number.number
    level_color: lime
    severity:
      - color: red
        value: 1
      - color: orange
        value: 29
      - color: lime
        value: 59
    card_mod:
      style: |
        ha-card {
        --ha-card-border-color: #ff000000 !important;
        #container {
        background: none !important;
        height: 160px;
        width: 112%;
        left: 30px;
        top: -100px;
        border-radius: 20px 20px 10px 10px !important;
    background_color:
      - 0
      - 0
      - 0
    full_value: "105"
card_mod:
  style:
    hui-image $: |
      img {
        z-index: 1 !important;
        position: relative !important;
        right: 0px;
        top: 0px;
        width: 15% !important;
        opacity: 1
      ha-card {
      background: black;
tank
Damn thanks so much that looks so good.
Not working for me though, using this config. Image shows and all just no fill effect.
image: /local/images/bottle.png
elements:
    card:
      type: glance
      show_name: false
      show_icon: false
      show_state: false
      entities:
        - entity: sensor.camper_gas_weight_right_bottle_2
    state_color: false
    fill_entity: sensor.camper_gas_weight_right_bottle_2
    level_color: lime
    severity:
      - color: red
        value: 1
      - color: orange
        value: 29
      - color: lime
        value: 59
    card_mod:
      style: |
        ha-card {
        #container {
        height: 160px;
        width: 112%;
        left: 30px;
        top: -100px;
    background_color:
      - 0
      - 0
      - 0
    full_value: "105"
card_mod:
  style:
    hui-image $: |
      img {
        right: 0px;
        top: 0px;
        opacity: 1
      ha-card {
      background: black;
Oh, I dont have card-mod, hold the line.
Damn, is there a way to do this without card-mod?
Why what is going on with card_mod?
It completely messes up my dashboard, i’ve tried using it like 10 times now (because it allows awesomeness) but everytime, it just renders my lovelace literally unusable.
It is so slow. When I click on an entity, it can take like 1 minute for the more-info window to show up.
Also, when editing cards in lovelace, the edit dialog for that card will show up once, and then when I try edit it again, just nothing displays, nothing pops up when trying to edit the card,
And a while bunch of other issues. :frowning:
Without card_mod, I’m not sure there is an option to use the tank image.
One option may be custom:button card. I’ll explore that method as it does not really require card_mod to customize the card. It is JavaScript based
  • Do you have HACS installed?
  • Can you currently still able use custom cards?
I would your post card_mod issues here for help with this. Your experience is not normal and I’d say something is really off.
UPDATE
custom:button-card is definitely an option with no card_mod needed
Untitled video - Made with Clipchamp (3)
Ahh yes, I know I NEED to sort this card-mod issue out, because it holds me back from some cool stuff,
But, if you can provide me with the button-card alternative for now that would be great.
Thank you!
This is the just the test code, but it can be significantly consolidated by controlling the gradient color off one sensor and making the card’s position static.
type: custom:button-card
entity_picture: /local/pics/bottle2.png
show_entity_picture: true
show_label: true
styles:
  entity_picture:
    - z-index: 1
custom_fields:
  level:
    card:
      entity: input_number.num2
      icon: mdi:battery
      tap_action: none
      show_state: false
      show_name: false
      show_icon: false
      styles:
        card:
          - left: "-275px"
          - top: |
                  if (states['input_number.num2'].state >=  30) return '-230px';
                  if (states['input_number.num2'].state >=  20) return '-210px';
                  if (states['input_number.num2'].state >=  0) return '-110px';
                  else return '0px';
          - position: absolute
          - background: |
                  if (states['input_number.num2'].state >=  30) return 'linear-gradient(rgba(0,0,0, .0) 0%, rgb(50, 205, 50)100%)';
                  if (states['input_number.num2'].state >=  20) return 'linear-gradient(rgba(0,0,0, .0) 30%, rgb(255, 165, 0)100%)';
                  if (states['input_number.num2'].state >=  0) return  'linear-gradient(rgba(0,0,0, .0)  10%, rgb(255, 0, 0)100%)';
                  else return 'black';
          - z-index: 1
          - height: |
                  if (states['input_number.num2'].state >=  30) return '180px';
                  if (states['input_number.num2'].state >=  20) return '150px';
                  if (states['input_number.num2'].state >=  0) return '50px';
                  else return '0px';
          - width: 59px
          - border-radius: 13px
          - margin-bottom: "-90px"
          - border: none
          - z-index: 0
        icon:
          - color: transparent
I will provide a final resolution…
Thank you!
i get a syntax error? I think I replaced everything with the correct entities.
entity_picture: /local/images/bottle.png
show_label: true
styles:
  entity_picture:
    - z-index: 1
custom_fields:
  level:
    card:
      entity: sensor.camper_gas_weight_left_bottle_2
      icon: mdi:battery
      tap_action: none
      show_state: false
      show_name: false
      show_icon: false
      styles:
        card:
          - left: "-275px"
          - top: |
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  30) return '-230px';
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  20) return '-210px';
                  if (states['sensor.camper_gas_weight_left_bottle_2].state >=  0) return '-110px';
                  else return '0px';
          - background: |
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  30) return 'linear-gradient(rgba(0,0,0, .0) 0%, rgb(50, 205, 50)100%)';
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  20) return 'linear-gradient(rgba(0,0,0, .0) 30%, rgb(255, 165, 0)100%)';
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  0) return  'linear-gradient(rgba(0,0,0, .0)  10%, rgb(255, 0, 0)100%)';
                  else return '0px';
          - z-index: 1
          - height: |
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  30) return '180px';
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  20) return '150px';
                  if (states['sensor.camper_gas_weight_left_bottle_2'].state >=  0) return '50px';
                  else return '0px';
          - width: 59px
          - border: none
          - z-index: 0
        icon:
Shit ok sorry found it after posting with larger text!
Thanks this looks good, just a few alignment issues, but this is clean
Missed a ' here
It will get cleaner
Yea sorry I actually saw that just as I posted, larger text.
Looking good, one more fine touch, is there a way to remove the gradient? So I can see the level more clearly?
Its looking good :slight_smile:
yes
- background: |
                  if (states['input_number.num2'].state >=  30) return 'lime';
                  if (states['input_number.num2'].state >=  20) return 'orange';
                  if (states['input_number.num2'].state >=  0) return  'red';
Im also trying to reduce the bottom margin, but for some reason its not reducing
Thanks, and margin top now a little high.
