Solutronic Inverter data as sensor value
Hi Forum.
I have a solar inverter that displays data in an HTML table, which I’d like to transfer to a sensor and monitor. What’s the correct method for this? Is it through scraping, using REST, or something entirely different?
I’ve managed to create a Python script that converts the HTML data into JSON, but I’m struggling to display it as a value in a sensor.
How should I proceed?
Here is an example of the data and the sensor I’ve tried without succes.
  - platform: file
    file_path: custom_components/solutronic/solutronic.py
    value_template: "{{ value_json | selectattr('ID', 'equalto', '001') | map(attribute='Value') | first }}"
    unit_of_measurement: 'kW'
    scan_interval: 5
and the json data:
        "ID": "005",
        "Label": "PAC",
        "Description": "Leistung AC",
        "Value": "394"
        "ID": "001",
        "Label": "PACL1",
        "Description": "power L1",
        "Value": "130"
        "ID": "002",
        "Label": "PACL2",
        "Description": "power L2",
        "Value": "136"
        "ID": "003",
        "Label": "PACL3",
        "Description": "power L3",
        "Value": "128"
Looking forward hearing from you.
Cheers, Rasmus
