As above…
~ $ ha supervisor update
Processing… Done.
Post “http://supervisor/supervisor/update”: context deadline exceeded (Client.Timeout exceeded while awaiting headers)
System Health
version: core-2021.4.6
installation_type: Home Assistant OS
dev: false
hassio: true
docker: true
virtualenv: false
python_version: 3.8.7
os_name: Linux
os_version: 5.4.83-v7
arch: armv7l
timezone: Europe/London
logged_in: false
can_reach_cert_server: ok
can_reach_cloud_auth: ok
can_reach_cloud: ok
host_os: Home Assistant OS 5.13
update_channel: stable
supervisor_version: supervisor-2021.04.0
docker_version: 19.03.15
disk_total: 57.8 GB
disk_used: 4.4 GB
healthy: failed to load: Unhealthy
supported: true
board: rpi3
supervisor_api: undefined
version_api: ok
installed_addons: Terminal & SSH (9.1.1), Check Home Assistant configuration (3.7.1), Duck DNS (1.12.5), File editor (5.3.0), Home Assistant Google Drive Backup (0.104.3)
dashboards: 1
resources: 4
mode: storage
Supervisor log
Task exception was never retrieved
future: <Task finished name=‘Task-91’ coro=<HomeAssistantWebSocket.async_supervisor_update_event() done, defined at /usr/src/supervisor/supervisor/homeassistant/websocket.py:138> exception=TypeError(‘Received message 257:None is not str’)>
File “/usr/src/supervisor/supervisor/homeassistant/websocket.py”, line 143, in async_supervisor_update_event
await self.async_send_command(
File “/usr/src/supervisor/supervisor/homeassistant/websocket.py”, line 134, in async_send_command
return await self._client.async_send_command(message)
File “/usr/src/supervisor/supervisor/homeassistant/websocket.py”, line 46, in async_send_command
response = await self.client.receive_json()
File “/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py”, line 291, in receive_json
data = await self.receive_str(timeout=timeout)
File “/usr/local/lib/python3.8/site-packages/aiohttp/client_ws.py”, line 276, in receive_str
raise TypeError(f"Received message {msg.type}:{msg.data!r} is not str")
TypeError: Received message 257:None is not str
Rebooted host, same deal…, ideas ?
