My system has been rock solid until this new release: it crashes multiple times daily, no difference between the .0 & .1 version.
I have cleaned up some stuff from my yaml files after the first fail but to no avail.
Restarting the home assistant service ‘solves’ it until the next crash.
Here is what I have in the log + some output from the status of the service:
2022-04-08 14:23:35 WARNING (SyncWorker_0) [homeassistant.loader] We found a custom integration browser_mod which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-08 14:23:35 WARNING (SyncWorker_1) [homeassistant.loader] We found a custom integration webrtc which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant
2022-04-08 14:23:35 WARNING (Recorder) [homeassistant.components.recorder.util] The system could not validate that the sqlite3 database at //home/homeassistant/.homeassistant/home-assistant_v2.db was shutdown cleanly
2022-04-08 14:23:35 WARNING (Recorder) [homeassistant.components.recorder.util] Ended unfinished session (id=74 from 2022-04-08 07:53:25.997193)
2022-04-08 14:23:41 WARNING (MainThread) [homeassistant.config_entries] Config entry 'Automatic' for knx integration not ready yet: No Gateways found; Retrying in background
2022-04-08 14:23:41 ERROR (MainThread) [homeassistant.components.camera.img_util] Error loading libturbojpeg; Cameras may impact HomeKit performance
File "/srv/homeassistant/lib/python3.9/site-packages/homeassistant/components/camera/img_util.py", line 96, in __init__
TurboJPEGSingleton.__instance = TurboJPEG()
File "/srv/homeassistant/lib/python3.9/site-packages/turbojpeg.py", line 298, in __init__
self.__find_turbojpeg() if lib_path is None else lib_path)
File "/srv/homeassistant/lib/python3.9/site-packages/turbojpeg.py", line 907, in __find_turbojpeg
raise RuntimeError(
RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually.
e.g. jpeg = TurboJPEG(lib_path)
2022-04-08 14:23:41 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'int' got invalid input 'unknown' when rendering template '{{ (states('sensor.sagem_internet_gateway_device_b_received') | int / 1000) | round(1) }}' but no default was specified. Currently 'int' will return '0', however this template will fail to render in Home Assistant core 2022.1
2022-04-08 14:23:41 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'int' got invalid input 'unknown' when rendering template '{{ (states('sensor.sagem_internet_gateway_device_b_sent') | int / 1000) | round(1) }}' but no default was specified. Currently 'int' will return '0', however this template will fail to render in Home Assistant core 2022.1
2022-04-08 14:23:48 WARNING (MainThread) [homeassistant.components.automation.mediaplayers_wake_up] Livingroom: Mediaplayers Wake-up: Already running
sudo systemctl status homeassistant.service
* homeassistant.service - Home Assistant
Loaded: loaded (/etc/systemd/system/homeassistant.service; enabled; vendor preset: enabled)
Active: failed (Result: signal) since Fri 2022-04-08 03:44:59 UTC; 3h 31min ago
Process: 8539 ExecStart=/srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant (code=killed, signal=KILL)
Main PID: 8539 (code=killed, signal=KILL)
CPU: 26min 2.779s
Apr 07 21:54:28 hass hass[8539]: 2022-04-07 21:54:28 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1744_symfonisk_rotary_remote_slk] Bedroom: Controller - IK>
Apr 07 21:54:28 hass hass[8539]: 2022-04-07 21:54:28 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1744_symfonisk_rotary_remote_slk] Error while executing au>
Apr 07 23:24:16 hass hass[8539]: 2022-04-07 23:24:16 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1744_symfonisk_rotary_remote_slk] Bedroom: Controller - IK>
Apr 07 23:24:16 hass hass[8539]: 2022-04-07 23:24:16 ERROR (MainThread) [homeassistant.components.automation.controller_ikea_e1744_symfonisk_rotary_remote_slk] Error while executing au>
Apr 08 03:44:59 hass systemd[1]: homeassistant.service: Main process exited, code=killed, status=9/KILL
Apr 08 03:44:59 hass systemd[1]: homeassistant.service: Killing process 8565 (rtsp2webrtc_v5_) with signal SIGKILL.
Apr 08 03:44:59 hass systemd[1]: homeassistant.service: Failed with result 'signal'.
Apr 08 03:44:59 hass systemd[1]: homeassistant.service: Consumed 26min 2.779s CPU time.
Active: active (running) since Fri 2022-04-08 14:23:34 UTC; 26s ago
Main PID: 33918 (hass)
Tasks: 32 (limit: 18992)
Memory: 184.5M
CPU: 8.773s
CGroup: /system.slice/homeassistant.service
|-33918 /srv/homeassistant/bin/python3 /srv/homeassistant/bin/hass -c /home/homeassistant/.homeassistant
`-33937 /home/homeassistant/.homeassistant/rtsp2webrtc_v5_amd64 {"server":{"http_port":"localhost:8083","ice_servers":["stun:stun.l.google.com:19302"]},"streams":{}}
Apr 08 14:23:41 hass hass[33918]: File "/srv/homeassistant/lib/python3.9/site-packages/turbojpeg.py", line 907, in __find_turbojpeg
Apr 08 14:23:41 hass hass[33918]: raise RuntimeError(
Apr 08 14:23:41 hass hass[33918]: RuntimeError: Unable to locate turbojpeg library automatically. You may specify the turbojpeg library path manually.
Apr 08 14:23:41 hass hass[33918]: e.g. jpeg = TurboJPEG(lib_path)
Apr 08 14:23:41 hass hass[33918]: 2022-04-08 14:23:41 WARNING (MainThread) [homeassistant.helpers.template] Template warning: 'int' got invalid input 'unknown' when rendering template >
Apr 08 14:23:48 hass hass[33918]: 2022-04-08 14:23:48 WARNING (MainThread) [homeassistant.components.automation.mediaplayers_wake_up] Livingroom: Mediaplayers Wake-up: Already running
