Hi everybody,
I have spent a lot of time over the last few weeks investigating the problem with the recursion error, which occurs quite frequently. Further down then my own programming tests and analyses with Powershell and Python, also the Errorfiles.
RecursionError: maximum recursion depth exceeded
Problem:
No caldav calendar is displayed. There are a lot of errors in logging (see bleow).
In my case I want to integrate a Synology calendar, which runs without problems with DavX on Android and ‘CalDAV Synchonizer’ on Windows 11 and 10.
To exclude problematic entries, a new user and completely new and empty calendar with only 2 entries and simple text was created.
It is unfortunately very difficult as a newbie to find his way around, what are old and outdated example configurations, what is still correct or what is new and to be considered.
Of course the #1 place to go is this one: CalDAV - Home Assistant
But since it doesn’t work, you search a lot on the internet.
Tested under
Home Assistant 10.4 and 10.5.
2023.8.0, 2023.8.1, 2023.8.2
Preliminary:
I have questions of understanding for the configuration, which are not clearly described for me.
configuration.yaml:
- does the user and password have to be in “” or not?
- is a http://ip/caldav… allowed or must it be a https:// connection?
- in many examples either ‘no calendar at all’, “calenders:” or “custom_calendars:” is specified as filter or selection.
Examples:
a.
calendar:
- platform: caldav
username: my_username
password: my_pwd
url: http://192.168.1.123:5000/caldav/my_user
b.
calendar:
- platform: caldav
password: my_pwd
calendars:
- "Family"
c.
calendar:
- platform: caldav
password: my_pwd
custom_calendars:
- name: "Family"
calendar: "Family"
search: "Family"
=> What is correct?
- what kind of restart do I need to do? Is
- any restart of ‘only one yaml file’ sufficient here when adjusting the configuration?
- Or a ‘quick start’ or
- must HA be completely restarted?
My research:
I have tried just about every possibility - so really in every combination.
- Name and password with and without “”
- All kinds of restarts
orurl: http://192.168.1.123:5000/caldav.php/my_user
- url:
or url:http://192.168.1.123:5000/caldav.php/
- url:
http://192.168.1.123:5000/caldav/my_user/home
After all this did not work, I made my own test query with powershell.
: The result was flawless. I was able to make a PROPFIND query and read all the data.
Then I took a closer look at the original HA Python scripts and the error message.
*CalDAV integration fails with RecursionError*
The user has a problem with CalDAV integration in Home Assistant. When trying to add a CalDAV calendar, a RecursionError occurs. The error occurs when Home Assistant tries to connect to the CalDAV server.
The file uses the caldav Python library to interact with CalDAV servers. This is made clear by the import caldav.
The connection to the CalDAV server is established with the following code:
client = caldav.DAVClient(url, None, username, password)
principal = client.principal()
calendars = principal.calendars()
Querying events from the calendar is done with the following code:
results = calendar.date_search(start_date, end_date)
I reprogrammed this - and what can I say: everything works fine - in my test environment.
Further in the logging and the displayed errors:
Error while setting up caldav platform for calendar
File “/usr/src/homeassistant/homeassistant/components/caldav/calendar.py”, line 87, in setup_platform
calendars = client.principal().calendars()
Based on this error message and the contents of the calendar.py file on GitHub, I can determine:
The error occurs in the setup_platform function of the calendar.py file.
More specifically, the error occurs when trying to call the calendars() method
of the principal object.
The relevant code snippet from the calendar.py file is:
The problem seems to occur when communicating with the CalDAV server via the caldav library, specifically when retrieving the calendar information of the principal object.
The error message further indicates that there is a recursive query that exceeds the maximum recursion depth. This suggests that there may be a problem with the caldav library itself or with the way Home Assistant uses it.
This appears to me to be indicated by the error:
File “/usr/local/lib/python3.11/site-packages/caldav/davclient.py”, line 654, in request
return self.request(url, method, body, headers)
So, why does it work in my rebuilt test in Python and Caldav and not in HA?
The only difference I can see right away is the version of Caldav. Newly installed I use the version 1.3.6. In HA unfortunately the quite old version 1.2.0 is still used. At least that’s how it seems to me:
➜ ~ docker exec -it homeassistant /bin/bash
homeassistant:/config# pip show caldav
Version: 1.2.0
Summary: CalDAV (RFC4791) client library
Home-page:https://github.com/python-caldav/caldav
Author: Cyril Robert
Author-email:[email protected]
License: GPL
Requires: icalendar, lxml, pytz, recurring-ical-events, requests, tzlocal, vobject
Required-by:
I have then also displayed the calendars in my Python query - that all works fine. Only HA refuses to work at all.
I am not fit in how I can update the HA Docker container permanently with Caldav 1.3.6.
Sure I have a
pip install caldav --upgrade
tried. But yes a service restart is probably needed - and bang, 1.2.0 of Caldav is available again.
I don’t know enough about how to get a permanent update for Caldav in this Docker.
Unfortunately, I can’t be sure if it’s really just that.
I’m also not sure if I’m using the right debug mode here. Maybe there would be more info to see where it really hangs.
In config.yaml I entered this, but I’m not sure wqelcher dein or entity is correct here:
logger:
default: info
logs:
homeassistant.components.calendar: critical
calendar.caldav: critical
What can I do now? Any suggestions?
Regards
Mike
