I can’t update to 2024.11 or 2024.11.1. As a result my companion apps are now refusing to connect, I can only access HA via a web browser at present.
I’ll add my logs below, hopefully someone can shed some light on this for me…
Core Log
Supervisor Log
Rollback Log
I was looking into this all day yesterday so I imagine there are many duplicates in there, my primary aim has been looking into the errors on the rollback log and trying to remove addons one by one with a restore done after each one to find the culprit but I have failed it seems.
There is a small chance that I mixed up the Core and Supervisor logs but both are there in their entirety
I’m running HA on a KVM virtual machine on my unraid NAS using the HAOS image
After opening a VM terminal I spotted lots of out of memory errors, I’ve upped the VM from 2gb to 4gb RAM and the update has applied without issue. Seems odd but I do have a few larger addons running on here I guess unless the minimum specs for HAOS have changed since I first set this up.
Thanks again for the assistance, you certainly pointed me in the right direction.
Hey guys, im having an issue updating to 2024.11.1 from 2024.10.4 as well. I can see a failure in my supervisor logs which ill include below. I had the same results when 2024.11.0 was release. I’m running an HA Yellow.
I’ve tried updating from within the home assistant settings as normal and I also tried in putty using the USB-C serial connection. both with the same results
e[32m2024-11-09 11:36:18.750 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/yellow-homeassistant:2024.10.4 to ghcr.io/home-assistant/yellow-homeassistant:2024.11.1e[0m
e[32m2024-11-09 11:36:18.750 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/yellow-homeassistant with tag 2024.11.1.e[0m
e[32m2024-11-09 11:38:48.135 INFO (SyncWorker_0) [supervisor.docker.manager] Stopping homeassistant applicatione[0m
e[32m2024-11-09 11:38:48.870 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API for d5369777_music_assistant closede[0m
e[32m2024-11-09 11:39:37.412 INFO (SyncWorker_0) [supervisor.docker.manager] Cleaning homeassistant applicatione[0m
e[32m2024-11-09 11:39:38.311 INFO (MainThread) [supervisor.homeassistant.module] Update pulse/client.config: /data/tmp/homeassistant_pulsee[0m
e[32m2024-11-09 11:39:38.666 INFO (MainThread) [supervisor.docker.homeassistant] Starting Home Assistant ghcr.io/home-assistant/yellow-homeassistant with version 2024.11.1e[0m
e[32m2024-11-09 11:39:38.667 INFO (MainThread) [supervisor.homeassistant.core] Wait until Home Assistant is readye[0m
e[31m2024-11-09 11:40:03.730 ERROR (MainThread) [supervisor.homeassistant.core] Home Assistant has crashed!e[0m
e[31m2024-11-09 11:40:03.730 CRITICAL (MainThread) [supervisor.homeassistant.core] HomeAssistant update failed -> rollback!e[0m
e[32m2024-11-09 11:40:03.734 INFO (MainThread) [supervisor.homeassistant.core] A backup of the logfile is stored in /config/home-assistant-rollback.loge[0m
Try this and see if you are getting out of memory errors too:
