What about during the update?
It doesn’t log anything from during the update. in that 3ish minute gap is when the supervisor logs that HA has crashed and its rolling back. At this point im either going to transition to something with more RAM to see if that helps or im going to get a CM 4 with more RAM. I have a small HP client not in use so i may just go with that. I would just hate to start from scratch
2024-11-10 00:38:28.102 homeassistant systemd[1]: systemd-timedated.service: Deactivated successfully.
2024-11-10 00:38:28.137 homeassistant kernel: audit: type=1334 audit(1731199108.129:1239): prog-id=252 op=UNLOAD
2024-11-10 00:38:28.137 homeassistant kernel: audit: type=1334 audit(1731199108.129:1240): prog-id=251 op=UNLOAD
2024-11-10 00:38:28.137 homeassistant kernel: audit: type=1334 audit(1731199108.129:1241): prog-id=250 op=UNLOAD
2024-11-10 00:41:45.497 homeassistant systemd[1]: docker-211024dddc7e60982f17a76d1f06ae088baaef9291ff0ef3606be04c774f63ec.scope: Deactivated successfully.
2024-11-10 00:41:45.499 homeassistant systemd[1]: docker-211024dddc7e60982f17a76d1f06ae088baaef9291ff0ef3606be04c774f63ec.scope: Consumed 5min 1.237s CPU time.
2024-11-10 00:41:45.521 homeassistant kernel: audit: type=1334 audit(1731199305.516:1242): prog-id=242 op=UNLOAD
2024-11-10 00:41:45.539 homeassistant dockerd[600]: time="2024-11-10T00:41:45.538928548Z" level=info msg="ignoring event" container=211024dddc7e60982f17a76d1f06ae088baaef9291ff0ef3606be04c774f63ec module=libcontainerd namespace=moby topic=/tasks/delete type="*events.TaskDelete"
I’ve got the same issue on a HA yellow. Its failed every update since 2024.10.4. I unfortunately do not have spare hosts to setup so I have to solve it on this one.
