(SOLVED) Convert dzvent Domoticz script to HA
Hi All,
Maybe a question thats not aswer full. But i want convert 1 script from Domoticz to HA.
Its a lot with if this then else etc etc.
Can someone help me out how to start this convertion?
local Version = '2019.06.23'
return {
    active = true,
	on = {
	devices = {[KodiStatus] = { 'at nighttime' }},
	-- logging = {marker = 'KODI Control ' ..Version..'...........'},
	execute = function(domoticz, device)
-- KODI PAUZE
    if ((domoticz.devices(SceneMovie).active or domoticz.devices(SceneTV).active) and
        (domoticz.devices(LogitechIPTV).active or domoticz.devices(LogitechKodi).active)
        ) then
        if (domoticz.devices(KodiStatus).state == 'Paused') then
            domoticz.globalData.KodiPlayVar = 0
            domoticz.globalData.KodiStopVar = 0
            -- HALLOWEEN
            if domoticz.helpers.halloween(domoticz) then
                domoticz.devices(BulbLivingroomAll).dimTo(100)
            -- X-MAS
            elseif domoticz.helpers.xmas(domoticz) then
            -- NORMAL
            else
            end
            -- SENSOR DINING ROOM ON
            if (domoticz.devices(SensorDiningRoomDoor).active) then
                domoticz.helpers.Off(domoticz,BulbDressoirAll)
            -- SENSOR DINING ROOM OFF
            elseif (not domoticz.devices(SensorDiningRoomDoor).active) then
                -- HALLOWEEN
                    domoticz.devices(BulbDressoirAll).dimTo(100)
                -- X-MAS
                -- BDAY
                elseif domoticz.helpers.bday(domoticz) then
                    domoticz.helpers.RGB(domoticz,BulbDressoir1,nil,'Red',nil)
                    domoticz.helpers.KELVIN(domoticz,BulbDressoir2,nil,0,nil)
                    domoticz.helpers.RGB(domoticz,BulbDressoir3,nil,'Blue',nil)
                -- NORMAL
                else
                end
            end
            domoticz.helpers.RGB(domoticz,BulbBalcony1,nil,'Blue',nil)
            domoticz.devices(BulbToiletAll).dimTo(100)
            domoticz.devices(BulbKitchenSinkAll).dimTo(100)
            domoticz.devices(BulbKitchenAll).dimTo(100)
            os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -b 50 &')
            --domoticz.log('------------------------==<[ KODI STAAT OP PAUZE ]>==-----------------------', domoticz.LOG_FORCE)
-- KODI VIDEO
        elseif (domoticz.devices(KodiStatus).state  == 'Video' and domoticz.globalData.KodiPlayVar == 0) then
            domoticz.globalData.KodiPlayVar = 1
            -- HALLOWEEN
                domoticz.devices(BulbLivingroomWall).dimTo(70)
                domoticz.devices(BulbLivingroomWindow).dimTo(20)
            -- X-MAS
            -- NORMAL
            else
            end
                -- HALLOWEEN
                    domoticz.devices(BulbDressoirAll).dimTo(25)
                -- X-MAS
                -- BDAY
                -- NORMAL
                else
                end
            end
            domoticz.helpers.Off(domoticz,BulbKitchenSinkAll)
            domoticz.helpers.Off(domoticz,BulbKitchenAll)
            domoticz.helpers.Off(domoticz,BulbToiletAll)
            domoticz.helpers.Off(domoticz,SwitchCooker)
            domoticz.helpers.RGB(domoticz,BulbBalcony1,25,'Blue',nil)
            os.execute('/home/pi/domoticz/scripts/Peter/Nanoleaf/nano.sh -b 30 &')
            --domoticz.log('------------------------==<[ KODI IS FILM AAN AFSPELEN ]>==-----------------', domoticz.LOG_FORCE)
-- KODI TV SHOW
        elseif (domoticz.devices(KodiStatus).state  == 'TV Shows' and domoticz.globalData.KodiPlayVar == 0)
        then
            -- HALLOWEEN
                domoticz.devices(BulbLivingroomWindow).dimTo(50)
            -- X-MAS
            -- NORMAL
            else
            end
                -- HALLOWEEN
                -- X-MAS
                -- BDAY
                -- NORMAL
                else
                end
            end
            --domoticz.log('------------------------==<[ KODI IS SERIE AAN AFSPELEN ]>==----------------', domoticz.LOG_FORCE)
-- KODI SPEELT NIKS
        elseif (domoticz.devices(KodiStatus).state  == 'On')
        then
            domoticz.globalData.KodiStopVar = 1
            -- HALLOWEEN
            -- X-MAS
            -- NORMAL
            else
            end
                -- HALLOWEEN
                -- X-MAS
                -- BDAY
                -- NORMAL
                else
                end
            end
            domoticz.helpers.RGB(domoticz,BulbBalcony1,75,'Blue',nil)
            --domoticz.log('------------------------==<[ KODI SPEELT NIKS AF ]>==-----------------------', domoticz.LOG_FORCE)
	    end
	end
end
I reply a bit late so I hope you’ve found a solution in beween, but just in case, the easiest way I found to migrate my dzVent scripts to HA is to use AppDaemon which enables you to write python scripts for HA. Then you just have to adapt your lua scripts to python. It takes a bit of time for the first one to get used to the different ways to call things, but after that it’s pretty straight forward.
Good luck.
thanks for the reply. In meanwhile I have migrate all my 38 dzvent scripts into HA. It took some days, because its totally different… in some way harder to understand. I miss the:
If LALALA then
action
if LALALA then
action
end
end
Maybe will understand in future how it will work with HA to have more IF statements inside them.
:smiley:
