[solved] Errors when removing/adding 'platform'
I’m trying to update devices from v2024.4.2
This is the current config:
esphome:
  comment: "${device_description}"
  platform: ESP8266
  esp8266_restore_from_flash: true
  board: d1_mini
  name_add_mac_suffix: false
  on_boot:
and
ota:
  password: <redacted>
If I add platform to the ota section I get an error for the one under esphome and if I remove that one, I also get an error… :thinking:
So I have no clue how to continue… :blush:
TIA
Nobody else has a clue either unless you say that the errors are.
The platform: key under ota: is a requirement now. If you omit that the build will stop at that point, masking the other unspecified error.
INFO ESPHome 2025.12.1
INFO Reading configuration /config/esphome/p1.yaml...
Failed config
esphome: [source /config/esphome/p1.yaml:7]
  Platform missing. You must include one of the available platform keys: esp32, bk72xx, libretiny, ln882x, rp2040, nrf52, host, rtl87xx, esp8266.
  comment: P1 module
  esp8266_restore_from_flash: True
  board: d1_mini
  name_add_mac_suffix: False
  on_boot:
    then:
      - if:
          condition:
            lambda: return id(has_key);
          then:
            - lambda: |-
So read the docs and do what the message said.
esp8266 is a top level key, it doesn’t go under esphome:. The format you were using was deprecated over three years ago and removed completely nearly a year ago.
Hi, thanks for pointing that out but I get 1 error after the other when I try to correct this and TBH I’m not that good in this.
The original configuration came with that setup and just now I thought of updating it.
esphome:
  comment: P1 module
  on_boot:
    then:
      - etc...
esp8266:
  board: d1_mini
Thanks Tom, this worked! :+1:
I didn’t know where to put what under those top levels. :bowing_man:
