I am trying to get a temperature value from Home Assistant that I want to present on a Max7219 Digit Display. But looking over my YAML and comparing other examples I can’t get it to work so hoping someone might help me out. It currently display’s 0.0°C. Without “has_state” would display “nan”. Time appears fine. See my YAML and Log below.
ESPHOME YAML;
esphome:
platform: ESP8266
board: d1_mini
wifi:
ssid: !secret wifi_ssid
password: !secret wifi_pswd
power_save_mode: none
ap:
ssid: " Display Fallback Hotspot"
password: !secret esphome_pswd
captive_portal:
logger:
api:
ota:
web_server:
port: 80
spi:
clk_pin: D5
mosi_pin: D7
font:
- file: "pixelmix.ttf"
glyphs:
- '0'
- '1'
- '2'
- '3'
- '4'
- '5'
- '6'
- '7'
- '8'
- '9'
- A
- B
- C
- D
- E
- F
- G
- H
- I
- J
- K
- L
- M
- N
- O
- P
- Q
- R
- S
- T
- U
- V
- W
- X
- Y
- Z
- _
- a
- b
- c
- d
- e
- f
- g
- h
- i
- j
- k
- l
- m
- n
- o
- p
- q
- r
- s
- t
- u
- v
- w
- x
- y
- z
display:
- platform: max7219digit
cs_pin: D8
num_chips: 8
intensity: 1
update_interval: 100ms
lambda: |-
it.strftime(0, 0, id(digit_font8), "%H:%M:%S", id(hass_time).now());
it.printf(65, 0, id(digit_font6), TextAlign::TOP_RIGHT, "%.1f°C", id(outside_temp).has_state());
time:
- platform: homeassistant
timezone: EST+5EDT,M3.2.0/2,M11.1.0/2
name: "Outside Temperature"
entity_id: sensor.rear_porch_sensor_temperature_measurement
internal: true
status_led:
pin:
number: GPIO2
Log;
[14:15:22][C][status_led:019]: Status LED:
[14:15:22][C][status_led:020]: Pin: GPIO2 (Mode: OUTPUT)
[14:15:22][C][wifi:443]: WiFi:
[14:15:22][C][wifi:303]: SSID: 'VikingBlod'[redacted]
[14:15:22][C][wifi:304]: IP Address: 192.168.1.235
[14:15:22][C][wifi:306]: BSSID: 00:11:32:9D:E1:29[redacted]
[14:15:22][C][wifi:307]: Hostname: 'dendisplay'
[14:15:22][C][wifi:311]: Signal strength: -44 dB ▂▄▆█
[14:15:22][C][wifi:315]: Channel: 2
[14:15:22][C][wifi:316]: Subnet: 255.255.255.0
[14:15:22][C][wifi:317]: Gateway: 192.168.1.1
[14:15:22][C][wifi:318]: DNS1: 192.168.1.177
[14:15:22][C][wifi:319]: DNS2: (IP unset)
[14:15:22][C][spi:081]: SPI bus:
[14:15:22][C][spi:082]: CLK Pin: GPIO14 (Mode: OUTPUT)
[14:15:22][C][spi:084]: MOSI Pin: GPIO13 (Mode: OUTPUT)
[14:15:22][C][spi:085]: Using HW SPI: NO
[14:15:22][C][logger:185]: Logger:
[14:15:22][C][logger:186]: Level: DEBUG
[14:15:22][C][logger:187]: Log Baud Rate: 115200
[14:15:22][C][logger:188]: Hardware UART: UART0
[14:15:22][C][homeassistant.time:010]: Home Assistant Time:
[14:15:22][C][homeassistant.time:011]: Timezone: 'EST+5EDT,M3.2.0/2,M11.1.0/2'
[14:15:22][C][max7219DIGIT:046]: MAX7219DIGIT:
[14:15:22][C][max7219DIGIT:047]: Number of Chips: 8
[14:15:22][C][max7219DIGIT:048]: Intensity: 1
[14:15:22][C][max7219DIGIT:049]: Scroll Mode: 0
[14:15:22][C][max7219DIGIT:050]: Scroll Speed: 250
[14:15:22][C][max7219DIGIT:051]: Scroll Dwell: 1000
[14:15:22][C][max7219DIGIT:052]: Scroll Delay: 1000
[14:15:22][C][max7219DIGIT:053]: CS Pin: GPIO15 (Mode: OUTPUT)
[14:15:22][C][max7219DIGIT:054]: Update Interval: 0.1s
[14:15:22][C][captive_portal:169]: Captive Portal:
[14:15:22][C][web_server:131]: Web Server:
[14:15:22][C][web_server:132]: Address: dendisplay.local:80
[14:15:22][C][ota:029]: Over-The-Air Updates:
[14:15:22][C][ota:030]: Address: dendisplay.local:8266
[14:15:22][C][ota:032]: Using Password.
[14:15:22][C][api:095]: API Server:
[14:15:22][C][api:096]: Address: dendisplay.local:6053
[14:15:22][C][homeassistant.sensor:024]: Homeassistant Sensor 'Outside Temperature'
[14:15:22][C][homeassistant.sensor:024]: Unit of Measurement: ''
[14:15:22][C][homeassistant.sensor:024]: Accuracy Decimals: 1
[14:15:22][C][homeassistant.sensor:025]: Entity ID: 'sensor.rear_porch_sensor_temperature_measurement'
