Hi all,
So, I have a wall switch (Simple rocker type) with a Sonof Mini behind it. This wall switch controls the lounge lights. I recently installed two lamps in my lounge; both connected to two son off basics.
I wanted to have an “automation” where if I toggle the wall switch (turn it on and off) within 350ms - the lamps turn on and the main lounge lights stay off.
I managed to do this by doing the following:
- Remove the config from ESPHome
- Setup a flow in NodRed (Which is connected to HA)
The flow in NodRed does this:
Switch stage changed -> did it do on and off within 350ms? - if so - turn lamps on - else toggle lounge lights
This got me the desired outcome. Then I got thinking; what happens if HA died? My wall switch would do nothing. Because I removed the config from ESPHome to turn on the relay / lights
So, this is my question
Is it possible to configure ESPHome to do the following:
“If switch status changes (off -> on -> off) within < 350mm -. ignore this.” Else turn on or off the light depending on the state of switch.
I have tried all sorts of things with if-conditions and such. But the lights “flicker” for a brief period when I toggle the switch.
This is my latest attempt:
binary_sensor:
- platform: gpio
pin: GPIO00
internal: true
# on_press:
# - light.toggle:
# id: lounge_lights
- platform: gpio
name: 'Lounge lights switch'
pin: GPIO04
on_press:
- if:
condition:
for:
time: 5s #added long delays for testing
condition:
- binary_sensor.is_on: switch_1
then:
- delay: 5s
- if:
condition:
- light.is_off: lounge_lights
then:
- light.turn_on: lounge_lights
on_release:
- if:
condition:
for:
time: 5s
condition:
- binary_sensor.is_off: switch_1
then:
- delay: 5s
- if:
condition:
- light.is_on: lounge_lights
then:
- light.turn_off: lounge_lights
