Can someone help me solve this error message it’s located under dev-info?
I’ve change my internal ip to: x.x.x.x.
2017-10-13 16:41:00 WARNING (MainThread) [homeassistant.setup] Setup of light is taking over 10 seconds.
2017-10-13 16:41:05 WARNING (MainThread) [homeassistant.components.light] Setup of platform hue is taking over 10 seconds.
2017-10-13 16:41:05 ERROR (Thread-19) [phue] POST Request to x.x.x.x/api timed out.
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 744, in connect
self.username = config[self.ip]['username']
KeyError: 'x.x.x.x'
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 653, in request
connection.request(mode, address, json.dumps(data))
File "/usr/lib/python3.5/http/client.py", line 1107, in request
self._send_request(method, url, body, headers)
File "/usr/lib/python3.5/http/client.py", line 1152, in _send_request
self.endheaders(body)
File "/usr/lib/python3.5/http/client.py", line 1103, in endheaders
self._send_output(message_body)
File "/usr/lib/python3.5/http/client.py", line 934, in _send_output
self.send(msg)
File "/usr/lib/python3.5/http/client.py", line 877, in send
self.connect()
File "/usr/lib/python3.5/http/client.py", line 849, in connect
(self.host,self.port), self.timeout, self.source_address)
File "/usr/lib/python3.5/socket.py", line 712, in create_connection
raise err
File "/usr/lib/python3.5/socket.py", line 703, in create_connection
sock.connect(sa)
socket.timeout: timed out
2017-10-13 16:41:05 ERROR (MainThread) [homeassistant.components.light] Error while setting up platform hue
KeyError: 'x.x.x.x'
self.send(msg)
self.connect()
raise err
sock.connect(sa)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/helpers/entity_component.py", line 164, in _async_setup_platform
SLOW_SETUP_MAX_WAIT, loop=self.hass.loop)
File "/usr/lib/python3.5/asyncio/tasks.py", line 400, in wait_for
return fut.result()
File "/usr/lib/python3.5/asyncio/futures.py", line 293, in result
raise self._exception
File "/usr/lib/python3.5/concurrent/futures/thread.py", line 55, in run
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/light/hue.py", line 138, in setup_platform
allow_in_emulated_hue, allow_hue_groups)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/light/hue.py", line 149, in setup_bridge
config_file_path=hass.config.path(filename))
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 629, in __init__
self.connect()
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 752, in connect
self.register_app()
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 706, in register_app
response = self.request('POST', '/api', registration_request)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/phue.py", line 661, in request
raise PhueRequestTimeout(None, error)
phue.PhueRequestTimeout: (None, 'POST Request to x.x.x.x/api timed out.')
2017-10-13 17:07:14 WARNING (Thread-25) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2017-10-13 17:07:14 WARNING (Thread-24) [pychromecast.socket_client] Heartbeat timeout, resetting connection
2017-10-13 17:07:44 ERROR (Thread-25) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2017-10-13 17:07:45 ERROR (Thread-24) [pychromecast.socket_client] Failed to connect, retrying in 5.0s
2017-10-13 18:02:57 WARNING (MainThread) [homeassistant.components.device_tracker.owntracks] Received unsupported message type: lwt.
2017-10-13 18:02:57 ERROR (MainThread) [homeassistant.core] Error doing job: Task exception was never retrieved
File "/usr/lib/python3.5/asyncio/tasks.py", line 239, in _step
result = coro.send(None)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/owntracks.py", line 80, in async_handle_mqtt_message
yield from async_handle_message(hass, context, message)
File "/srv/homeassistant/homeassistant_venv/lib/python3.5/site-packages/homeassistant/components/device_tracker/owntracks.py", line 413, in async_handle_message
yield from handler(hass, context, message)
TypeError: 'NoneType' object is not callable
