Hi, I was previously running on a Rpi 3 with SSD. My new Rpi 4 8GB just arrived and I wanted to transfer my setup to the new Rpi 4.
So I flashed the SSD with a the latest 6.4 copy (Rpi 4 64bit). It boots fine and I can get to the WebUI. But then gets stuck in “Preparing Home Assistant” forever. Clicking on the blue dot gives shows me this log below. This is a headless install as I don’t have a micro HDMI yet to plug in and have a look.
The weird thing is that I also flashed the exact same copy into a temporary 16GB SD Card, and the install finished fine. This SSD was flashed with 5.12 when it was on the Rpi 3 in June 2021 and it was working fine. I can’t understand what could be the difference between the SD card and SSD that would give this error. Is there something I needed to change on my SSD?
Any ideas would be appreciated. Its been 9 months into my HA journey and was hoping the Rpi 4 + SSD would solve my stability issues that plagued by Rpi 3 set up. I’m just about to give up on HA…
21-09-14 22:13:06 INFO (SyncWorker_1) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6
21-09-14 22:13:06 INFO (SyncWorker_1) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2021.9.6.
21-09-14 22:15:06 ERROR (SyncWorker_1) [supervisor.docker.interface] Can't install ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6: 404 Client Error for http+docker://localhost/v1.41/images/ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6/json: Not Found ("no such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6: No such image: ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6")
21-09-14 22:15:06 WARNING (MainThread) [supervisor.homeassistant.core] Error on Home Assistant installation. Retry in 30sec
21-09-14 22:15:36 INFO (SyncWorker_3) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:landingpage to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2021.9.6
21-09-14 22:15:36 INFO (SyncWorker_3) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2021.9.6.
(this can take up to 20 minutes)
