[SOLVED] Hass.io addon USB open serial error - De Dietrich
I’m migrating from a Pi3 without HassIO to a brand new install using HassIO on a Pi4.
In my setup I have a python script that pulls data from my heater using serial interface and push it to MQTT (using https://github.com/enc-X/isystem-to-mqtt to be precise).
I have an issue with migrating this, I wrote a simple addon to be able to launch it (I’m familiar with Docker so I don’'t think I made a mistake here).
But when I start it, I get a serial.serialutil.SerialException: Port is already open.
I tried mapping my device by using auto_uart flag in config.json and then by using the devices binding, but without any change.
Does anybody have any idea of what can be using the port ? I looked around my setup and did not find anything related to it (I have a rfxtrx addressed by its id and a zwave stick also, which are working flawlessly).
Regards
As always, it is when you ask for help that you find a fix.
It seems that my problem was only due to a bug in code, I forked the repository, added a self.socket.close() before opening and everything now works flawlessly.
I think the python version I was using on my pi3 was not behaving the same way regarding this…
Issue closed :slight_smile:
