[SOLVED] Help in Creating Conditional Cards
Hello everyone,
I would like a bit of your help regarding Conditional Cards.
I have two things I want to create.
Firstly, I have my water heater set up with an automation to turn off after 25 minutes when I turn it On. So, I want to create a Conditional Card where, when it detects the water heater is on, it displays a card with a 25-minute countdown. I’ve managed to create a helper and include it in the card, but I haven’t found an option to automatically trigger it when the water heater turns on.
type: conditional
conditions:
  - condition: state
    entity: switch.sonoff_10018cb227
    state: 'on'
card:
  type: entities
  entities:
    - entity: timer.water_heater
  state_color: true
The other issue I have is that I want to create a Conditional Card containing all my media players. Ideally, I would like it to display only the active one(s) each time. Is this possible?
Below is my first attempt but it doesn’t work.
type: conditional
conditions:
  - condition: state
    entity: media_player.nicks_tv_3
    state_not: 'off'
  - entity: media_player.plex_plex_for_android_tv_nick_s_tv
    state_not: 'off'
  - entity: media_player.playstation_5
    state_not: 'off'
  - entity: media_player.spotify_nick
    state_not: 'off'
card:
  type: custom:layout-card
  layout_type: custom:masonry-layout
  layout: {}
  cards:
    - type: media-control
      entity: media_player.plex_nick_sony_tv
Not sure exactly what you are asking for here but, if you want the card to show when the timer is running, try this:
  - type: conditional
    conditions:
      state_not: idle
    card:
When you create a Conditional Card, you see a big blue field which says that all conditions must be met. So if one mediaplayer is off, the card will not be displayed. Use a Filter Card instead, example:
type: entity-filter
entities:
  - media_player.sony
  - media_player.echo_dotchen
state_filter:
  - operator: '!='
    value: 'off'
card:
The entities that meet the conditions will automatically be displayed without defining them again in the custom card.
The timer starts when you add another action to your automation:
service: timer.start
  duration: "0:25:0"
  entity_id: timer.xy
Thank you for your reply, I really appreciate it.
I attempted your suggestion, and while it worked, I encountered two issues.
1st, despite using the same card layout, the display appears different, lacking the image of the media and the controls.
and the second one is when plex and Spotify are inactive, the cards are keep being visible.
type: entity-filter
entities:
  - media_player.sony_ke_55xh9077
  - media_player.plex_nick_sony_tv
  - media_player.playstation_5
  - media_player.spotify_nick
state_filter:
  - operator: '!='
    value: 'off'
card:
  layout: {}
Regarding the timer for the life of me I cannot get it to work… I definitely do something wrong.
Following jchhnot John advise nothing changed.
as for pedolsky I could not add your code into the automation.
Timer: It’s simply
    - service: timer.start
        duration: "0:25:0"
        entity_id: timer.your_timer
Filter Card: Expected behaviour because the player is not off (it’s idle). Change the state-filter to
state_filter:
  - operator: '=='
    value: 'playing'
or access the extended functionality by using entity:
type: entity-filter
entities:
  - entity: media_player.sony
    state_filter:
    - operator: '!='
      value: 'off'
  - entity: media_player.echo_dotchen
    state_filter:
    - operator: '!='
      value: 'idle'
card:
I can’t explain why the Media Control Card looks different for Spotify, I only heard rumours that the API makes problems sometimes.
Have you tried to put back the cards in Layout Card?
It’s not just the Spotify, its all the cards. they are not displaying as Media Cards.
I’ve tried
card:
  type: media-control
but with no success
As for the timer
I want to create a card that is displaying the timer only when the water heater is on.
And I want for the timer to start when the state of the heater is turned to on.
I’ve tried something like this
type: conditional
conditions:
  - condition: state
    state: 'on'
card:
  type: entities
  entities:
  state_color: true
I can confirm that the Filter Card is buggy. Somit isn’t an option currently.
Timer:
Did you adjust your automation as what I suggested?
I believe I’ve got it!
type: entity-filter
entities:
  - entity: media_player.sony_ke_55xh9077
    type: media-control
    artwork: cover
    icon: ''
    state_filter:
      - operator: '!='
        value: 'off'
  - entity: media_player.plex_nick_sony_tv
    type: media-control
    artwork: cover
    icon: ''
    state_filter:
      - operator: '!='
        value: unavailable
    type: media-control
    artwork: cover
    icon: ''
    state_filter:
      - operator: '!='
        value: 'off'
  - entity: media_player.spotify_nick_
    type: media-control
    artwork: cover
    icon: ''
    state_filter:
      - operator: '!='
        value: idle
card:
  layout: {}
I don’t understand what exactly I must add to the automation…
alias: Heater Timer
description: ""
  - platform: state
    entity_id:
      - switch.sonoff_10018cb227
    to: "on"
condition: []
  - delay:
      hours: 0
      minutes: 25
      seconds: 0
      milliseconds: 0
  - type: turn_off
    device_id: c79893cf75ff471bf568c96bb6e4c9ca
    entity_id: e068115a0891bc527dd5733c25cf339c
    domain: switch
mode: single
See my comment above. Add another action to your action part.
alias: Heater Timer
description: ""
  - platform: state
    entity_id:
    to: "on"
condition: []
      duration: "0:25:0"
  - delay:
      hours: 0
      minutes: 25
      seconds: 0
      milliseconds: 0
  - type: turn_off
    domain: switch
mode: single
