[solved] Help needed for dynamic light groups
Having tried a variety of things I have hit a brick wall so looking for help!
Issue - I am trying to create a Lovelace picture card where I can place mushroom chips (or similar) which when tapped add them to a grroup. The goal being that group can then be used with a colour-wheel to set multipe LEDs to the same setting. It was all going perfectly until I realised group.xxx cannot be used with the colour-wheel of custom:light-entity-card and to the best of my knowledge you cannot use the service group.set to add to a light group.
What I have done so far is:
  1. created a picture entity with mushroom-chips for LED spotlights:
with an extract of the card yaml being:
type: picture-elements
image: local/floorplan_ground2.png
elements:
  - type: custom:mushroom-chips-card
    style:
      top: 16.75%
      left: 82%
    card_mod:
      style: |
        ha-card {
          --chip-box-shadow: none;
          --chip-spacing: 50;
          margin-right: 34px;
          --chip-height: 30px;
    chips:
      - type: light
        entity: light.playroom_l5
        content_info: none
        card_mod:
          style: |
            ha-card {
              --chip-background: {% if "light.playroom_l5" in state_attr("group.dynamic_lights","entity_id") %} pink
                                    {% else %} white
                                    {% endif %}
        tap_action:
          action: call-service
          service: script.group_change
          service_data:
            selected_light: light.playroom_l5
with the script being a simple:
alias: Group change
sequence:
  - service: group.set
      object_id: dynamic_lights
      add_entities: "{{selected_light}}"
mode: single
However this is a dead-end as it needs to be a light group for the custom card. Any ideas please???
(on a side topic I have used the style template for changing the background of a chip based on whether it is in group.dynamic_lights, which means I replacate the code for each and every bulb - is there a better way that can do this by calling a routine which passes the entity_id somewhere?)
Any help hugely appreciated.
S.
Solved! It was as simple as turning on ‘forced features’ in the light-entiy-card!
