[SOLVED] Help with a value_template if then statement
what am I doing wrong with the below ?
    value_template: >
      {%- if is_state("states.sensor.plex_vintnet_stats.attributes['andrew.vint']['full_title']", null }
        'Idle'
      {%- else -%}
      {%- endif -%}
Copy and paste your template in Dev Tools/templates and you will see what you get.
BTW, your missing a ‘%’ on the end of the first line.
EDIT, and a closing bracket too.
figured out the following, however when I put it into the config.yaml I keep getting an error;
below is the script
     {% if states.sensor.plex_vintnet_stats.attributes['andrew.vint']['Activity'] is defined %}
    Idle
 {% else %}
    {{states.sensor.plex_vintnet_stats.attributes['andrew.vint']['full_title']}}
     {% endif %}
Below is how it appears in the config.yaml file
    value_template: >-
    Idle
  {% else %}
      {% endif %}
Below is the error message when I run the Check Config
Error loading /config/configuration.yaml: while scanning for the next token
found character ‘\t’ that cannot start any token
in “/config/configuration.yaml”, line 649, column 1
This means you have tabs in your yaml.
Yaml should only intended with spaces.
    Idle
  {% else %}
  {% endif %}
you were spot on @VDRainer … I spent hours on that at it was a simple as a tab
Thank you so much
