[solved] How to configure these simple single, oldskool RGB LEDs?
I'm trying to add this kind of LED
to a Wemos S3 mini but I cannot figure out how to configure it.
It's a common cathode type and I have put 200Ohm resistors on the anodes so I guess that part is OK.
EDIT: the solution was given by @Karosm and this post shows the full code
EDIT 2: the code for a Lolin D1 mini (esp8266) is in this post
Cathode to GND and anodes to gpio pins via resistors. On your code make LEDC outputs for those gpios and RGB light component to control outputs.
Hi guys, thanks for helping out!
I was already searching for hours but couldn't find what to use for coding.
Just now, I got it working like this:
output:
  - platform: ledc
    pin: GPIO16
  - platform: ledc
    pin: GPIO18
  - platform: ledc
    pin: GPIO35
light:
  - platform: monochromatic
    output: gpio_16
    output: gpio_18
    output: gpio_35
Although I like ESPHome very much as a technology but TBH, I still don't know if this is the right and only way for this kind of LED and I struggle each time when trying something new... :blush:
It's more "common" to use single RGB-light component than multiple mono.
Like @Karosm said - use a single light component:
output:
  - platform: ledc
    pin: GPIO16
  - platform: ledc
    pin: GPIO18
  - platform: ledc
    pin: GPIO35
light:
  - platform: rgb
    red: gpio_16
    green: gpio_18
    blue: gpio_35
Anyone knows what is needed to make this work on a D1 mini (esp8266)?
Just replace LEDC outputs with:
output:
  - platform: esp8266_pwm
It's software pwm though...
You are quick on the ball! :person_bowing:
The code for a Lolin D1 mini (esp8266)
output:
    pin: GPIO12
    pin: GPIO13
    pin: GPIO15
light:
  - platform: rgb
    red: gpio_12
    green: gpio_13
    blue: gpio_15
What does that mean 'software pwm'?
Esp8266 doesn't have dedicated peripheral for PWM like esp32 has. So it's using cpu resources and has some limitations compared to LEDC.
