This will be a simple question for many of you, but too complicate for me.
I would like to have a graph (stat card) that has two curves being the set- (target) temperature and the reference- (actual) temperature of a climate instance.
How would I need to do this?
Thanks in advance, Yann
I figured out I can get the set temperature as follows
{{state_attr("climate.living_heating","temperature")}}
But how do I get that into a graph say in a Statistics Graph Card
Should I use an
number_input
helper or create a
sensor
? And if so, what platform ?
I figured it out and created the following entry in ./templates.yaml
# check https://www.home-assistant.io/docs/configuration/templating/
- sensor:
- name: "living demand temperature"
unique_id: "2022113011298765-4356"
unit_of_measurement: "°C"
state: '{{state_attr("climate.living_heating","temperature") | float(0) }}'
state_class: measurement
device_class: temperature
And this gives me the sensor
sensor.living_demand_temperature
That can be used is e.g. a Statistics Graph Card
