[solved] (I was the issue) Unable to update from 2025.6.3 to 2025.7.0
Hey all,
I am trying to get the latest update but it just keeps getting stuck on installing,
the supervisor log states its downloading the update but now its been stuck for an hour on installing…
e[32m2025-07-03 13:01:41.470 INFO (MainThread) [supervisor.homeassistant.core] Updating Home Assistant to version 2025.7.0e[0m
e[32m2025-07-03 13:01:41.472 INFO (MainThread) [supervisor.docker.interface] Updating image ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.6.3 to ghcr.io/home-assistant/raspberrypi4-64-homeassistant:2025.7.0e[0m
e[32m2025-07-03 13:01:41.473 INFO (MainThread) [supervisor.docker.interface] Downloading docker image ghcr.io/home-assistant/raspberrypi4-64-homeassistant with tag 2025.7.0.e[0m
e[32m2025-07-03 13:03:31.327 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:03:31.330 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:03:31.336 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:03:31.531 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:08:31.568 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:08:31.570 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:08:31.576 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:08:31.774 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:13:31.798 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:13:31.800 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:13:31.806 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:13:32.006 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:18:32.033 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:18:32.036 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:18:32.042 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:18:32.228 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:23:32.245 INFO (MainThread) [supervisor.homeassistant.api] Updated Home Assistant API tokene[0m
e[32m2025-07-03 13:23:32.250 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:23:32.252 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:23:32.258 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:23:32.442 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:28:32.469 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:28:32.472 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:28:32.478 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:28:32.668 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:33:32.707 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:33:32.711 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:33:32.717 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:33:32.917 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
e[32m2025-07-03 13:36:09.983 INFO (MainThread) [supervisor.resolution.check] Starting system checks with state runninge[0m
e[32m2025-07-03 13:36:09.983 INFO (MainThread) [supervisor.resolution.checks.base] Run check for trust/supervisore[0m
e[32m2025-07-03 13:36:29.524 INFO (MainThread) [supervisor.resolution.checks.base] Run check for disabled_data_disk/systeme[0m
e[32m2025-07-03 13:36:29.525 INFO (MainThread) [supervisor.resolution.checks.base] Run check for pwned/addone[0m
e[32m2025-07-03 13:36:30.746 INFO (MainThread) [supervisor.resolution.checks.base] Run check for docker_config/systeme[0m
e[32m2025-07-03 13:36:30.747 INFO (MainThread) [supervisor.resolution.checks.base] Run check for free_space/systeme[0m
e[32m2025-07-03 13:36:30.750 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_ipv6_error/dns_servere[0m
e[32m2025-07-03 13:36:30.751 INFO (MainThread) [supervisor.resolution.checks.base] Run check for dns_server_failed/dns_servere[0m
e[32m2025-07-03 13:36:30.752 INFO (MainThread) [supervisor.resolution.checks.base] Run check for security/coree[0m
e[32m2025-07-03 13:36:30.753 INFO (MainThread) [supervisor.resolution.checks.base] Run check for ipv4_connection_problem/systeme[0m
e[32m2025-07-03 13:36:30.753 INFO (MainThread) [supervisor.resolution.checks.base] Run check for multiple_data_disks/systeme[0m
e[32m2025-07-03 13:36:30.754 INFO (MainThread) [supervisor.resolution.checks.base] Run check for no_current_backup/systeme[0m
e[32m2025-07-03 13:36:30.756 INFO (MainThread) [supervisor.resolution.check] System checks completee[0m
e[32m2025-07-03 13:36:30.756 INFO (MainThread) [supervisor.resolution.evaluate] Starting system evaluation with state runninge[0m
e[32m2025-07-03 13:37:35.832 INFO (MainThread) [supervisor.resolution.evaluate] System evaluation completee[0m
e[32m2025-07-03 13:37:35.833 INFO (MainThread) [supervisor.resolution.fixup] Starting system autofix at state runninge[0m
e[32m2025-07-03 13:37:35.833 INFO (MainThread) [supervisor.resolution.fixup] System autofix completee[0m
e[32m2025-07-03 13:38:32.963 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initializee[0m
e[32m2025-07-03 13:38:32.965 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrasee[0m
e[32m2025-07-03 13:38:32.971 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy runninge[0m
e[32m2025-07-03 13:38:33.163 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closede[0m
2025-07-03 13:43:33.183 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2025-07-03 13:43:33.186 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrase
2025-07-03 13:43:33.192 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy running
2025-07-03 13:43:33.395 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closed
2025-07-03 13:48:33.425 INFO (MainThread) [supervisor.api.proxy] Home Assistant WebSocket API request initialize
2025-07-03 13:48:33.427 INFO (MainThread) [supervisor.api.proxy] WebSocket access from core_speech-to-phrase
2025-07-03 13:48:33.434 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API proxy running
2025-07-03 13:48:33.630 INFO (MainThread) [supervisor.api.proxy] [core_speech-to-phrase] Home Assistant WebSocket API closed
aparently I was just being very impatient,
After 1 hour and 45 minutes, the system finally rebooted and is now updated.
Lol what are you running Ha on? A Pi 2? :stuck_out_tongue:
PS - that is not how you mark your thread as solved.
I am running it on a pi 4B 4gb,
but its weird because previous .0 updates were quite rapid.
