[SOLVED] Integrations missing after updating to 0.109
Everything is working, as far as I can tell, but none of my integrations are showing in the integration-page.
I have rebooted twice.
Any suggestions?
This is my log:
2020-04-29 21:16:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for alexa_media which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-29 21:16:39 WARNING (MainThread) [homeassistant.loader] You are using a custom integration for hacs which has not been tested by Home Assistant. This component might cause stability problems, be sure to disable it if you experience issues with Home Assistant.
2020-04-29 21:16:39 WARNING (MainThread) [homeassistant.components.recorder] The 'purge_interval' option (with value '2') is deprecated, please remove it from your configuration
2020-04-29 21:16:48 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue for garmin_connect doing I/O at homeassistant/components/garmin_connect/__init__.py, line 98: self.data = self.client.get_stats_and_body(today.isoformat())
2020-04-29 21:16:49 WARNING (MainThread) [homeassistant.util.async_] Detected I/O inside the event loop. This is causing stability issues. Please report issue for garmin_connect doing I/O at homeassistant/components/garmin_connect/__init__.py, line 98: self.data = self.client.get_stats_and_body(today.isoformat())
2020-04-29 21:17:02 WARNING (MainThread) [homeassistant.components.switch] Setup of switch platform alexa_media is taking over 10 seconds.
2020-04-29 21:17:02 WARNING (MainThread) [homeassistant.components.sensor] Setup of sensor platform alexa_media is taking over 10 seconds.
2020-04-29 21:17:04 WARNING (MainThread) [homeassistant.helpers.translation] alexa_media: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:04 WARNING (MainThread) [homeassistant.helpers.translation] hacs: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:05 WARNING (MainThread) [homeassistant.helpers.translation] hacs: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:05 WARNING (MainThread) [homeassistant.helpers.translation] alexa_media: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:06 WARNING (MainThread) [homeassistant.helpers.translation] alexa_media: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:06 WARNING (MainThread) [homeassistant.helpers.translation] hacs: the '.translations' directory has been moved, the new name is 'translations', starting with Home Assistant 0.111 your translations will no longer load if you do not move/rename this
2020-04-29 21:17:07 ERROR (MainThread) [homeassistant.components.websocket_api.http.connection.140394681856272] Error handling message: required key not provided @ data['category']. Got None
Never mind, its a browser cache thing.
Works fine in incognito mode.
Case closed.
