I’m trying to add a temperature graph to lovelace from a sensor. According to [1] it should happen automatically when “unit_of_measurement” is defined for the sensor. But when I add the history graph card I end up with “Recent Switches” view from [1].
Here are the attributes for “sensor.fibaro_system_fgdw002_door_opening_sensor_2_temperature”:
node_id: 17
value_index: 1
value_instance: 1
value_id: 72057594328137746
unit_of_measurement: °C
friendly_name: Temperatur loft
The temperature reading seem correct. What am I doing wrong?
When you view the History page, and scroll to the bottom where all graphed entities are displayed, do you see the fibaro temperature sensor as a graph?
For example:
Or is it displayed elsewhere in the History view as a horizontal bar chart?
All of a sudden the graph is now shown correctly! I haven’t done anything… The only reason I can come up with, is that the sensor now has been active for more than 24 hours which is the interval i use for the graph.
It’s based on the database and your current browser cache. This is normal when you add unit_of_measurement to an existing item. Next time, delete your database and it will instantly update. Or wait like you did.
