I am trying to make kind of an access controll System using the OTP Integration, but i am on a RPI 4 b+ Running the Hassio Image, so i cant do the Commands given in the Description of the Integration.
Can you please help me, i am a HA noob and habe switched from openHAB 3 a few weeks ago.
(The idea is that i put a card in my main dashboard with my location on it, but only Show it if the correct code (from my otp App) is entered in a text field)
As far as i know, the token
is up to your definition. The explanation in the documentation is just a generator for that token
, but you can put in there whatever you want.
Have you tried using a combination of letters as your token? Something like “IREALLYLOVEHANOW”. This token you set in your configuration.yaml
and put it in your authenticator app.
Thanks for the fast reply.
How do i get the current code?
Is it an entity?
Just to clear this, here is my configuration.yaml part for otp:
- platform: otp
token: AD3435776767676
EDIT: found the solution myself from an error message in my otp App that said the token is too short and contains invalid characters
Learned something again. Good it’s working for you!
