Solved - Radiator valve _TZE200_chyvmhay TS0601 show wrong temperature / not work
i am am new to hass. I have a lidl home gateway connected via ZHA (Zigbee Home Automation) in home assistant see link.
Lightbulbs and powerswitches worked nearly out of the box :slight_smile:
I have trouble setting up the radiator valves (_TZE200_chyvmhay TS0601).
I read this link now i am unsure how to get it work.
I have set up mqtt broker / mqtt but sadly no new devices are discovered.
Silvercrest Radiator Valve Controller
Model TVR01 manufactured by Lidl
Maybe i made a mistake in the config of them…
I dont know how to put things like together without zigbee2mqtt.
Do i need zigbee2mqtt for this device?
Greetings Schnabulator
After googling around it looks like “zha-quirks” is needed for ZHA.
I found this quirk that fit for this type of Radiator Valves
I have trouble to set up zha-quirks and dont know where to copy ts0601_trv_maxsmart.py.
Can you help me ?
EDIT:
pypi:
  - zha-quirks==0.0.65
apk: []
and copy quirk to directory :slight_smile:
/config/deps/lib/python3.9/site-packages/zhaquirks/lidl
