[SOLVED] reed-switch action: turns on/off led
esphome:
  friendly_name: [your choice]
esp8266:
  board: esp01_1m
# Enable logging
logger:
# Enable Home Assistant API
api:
  encryption:
    key: !secret api_key
ota:
  password: !secret ota_pw
wifi:
  ssid: !secret wifi_ssid
  domain: ".local"
  manual_ip:                                    # static IPs are a musthave - imo
    static_ip: 192.168.1.51
    gateway: 192.168.1.1
    subnet: 255.255.255.0
  ap:
    ssid: !secret ap_ssid
    password: !secret ap_pw
captive_portal:
#                   U S E F U L L   I N F O R M A T I O N  ?                   #
# First i tried this :                                                         #
# binary_sensor:                                                               #
#   - platform: gpio                                                           #
#     pin:        #
#       inverted: true                                                         #
#         - light.turn_on: kontroll_led_reed_wz                                #
#         - light.turn_off: kontroll_led_reed_wz                               #
# BUT:        #
# * on Dashboard (HA-Overview) :                                               #
#     - turns on led-icon, if switch-parts are far away from each other => OK! #
#     - texted "reed_wz_pin - closed" => physically OK, but could force        #
#       individual brain-errors of confusion                                   #
#       (led on: means door is open, but switch called 'closed' => LOL)        #
# So i changed the code to below ;-) :                                         #
# NOW:        #
# led on -> door open, switch called 'open'                                    #
# => no confusion by this anymore (?)                                          #
binary_sensor:
  - platform: status
  - platform: gpio
    pin:
      number: GPIO14         # Switch: connect one wire to this, the other to GND
      mode: INPUT_PULLUP
    #  inverted: true        # doesn't work the way you want? -> set to false or comment
    device_class: door
    on_press:                # reed-contact physically closed ? => YES
      then:
    on_release:              # reed-contact physically open ? => YES
      then:
output:
  - id: led_output
    platform: gpio
    pin: GPIO12
    # inverted: true
light:
  - platform: binary
    output: led_output
I hope, it helps somebody …
So long
