I am trying to remotely access my home assistant which sits behind a CGNAT. Apart from the remote access, my HA installation works perfectly well.
My Setup:
Home Assistant 0.116.4 using official docker container in Unraid
Nginx Proxy Manager running in docker container on Unraid
Packetriot running in docker container on Unraid
HA Configuration I have included the following in my HA configuration (I added to trusted proxies because I tried both directly from packetriot into HA as well as from packetriot>Nginx>HA).
http:
use_x_forwarded_for: true
trusted_proxies:
- 172.18.0.4
- 172.18.0.8
Nginx setup following this setup. Not enabled any https/LetsEncrypt yet. Enabled Websocket support in Nginx
Packetriot setup has an http tunnel to my domain home.example.nl with --destination NginxProxyManager
, and redirect=false
(so no redirecting of http to https). Exact command below, in case someone is familiar with Packetriot
pktriot tunnel http add --destination NginxProxyManager --redirect=false --http 8080 --domain home.example.nl
Behaviour
I am prompted with the login screen, if I supply the wrong credentials it tells me the credentials are wrong. If I enter the correct credentials it redirects to home.example.nl/lovelace with the message “Unable to connect to Home Assistant.” and a button to Retry.
In my Home Assistant logs I find:
[homeassistant.components.websocket_api.http.connection.22593065770000] Disconnected: Did not receive auth message within 10 seconds
I have found many similar questions and issues, but none of the solutions suggested there have helped me. Has anyone else encountered this problem?
