Hello everyone,
Still new to HA, I’m trying to add some automations to my setup from the GUI but fails everytime and I cannot figure out why…
The automation is quite simple : send a notification to my phone everytime my door sensor changes state.
When I hit the save button HA shows a 500 error.
Server logs looks like this :
homeassistant | 2025-07-05T08:35:43.614163981Z 2025-07-05 10:35:43.604 ERROR (SyncWorker_4) [homeassistant.util.file] Saving file failed: /config/automations.yaml
homeassistant | 2025-07-05T08:35:43.614273775Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:35:43.614307849Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:35:43.614339163Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:35:43.614367847Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:35:43.614394828Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:35:43.614422180Z next(self.gen)
homeassistant | 2025-07-05T08:35:43.614449105Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.614523215Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:35:43.614545289Z self.commit(f)
homeassistant | 2025-07-05T08:35:43.614561066Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:35:43.614576714Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:35:43.614593621Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:35:43.614609510Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.614625361Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:35:43.614643065Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:35:43.614658675Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:35:43.614675416Z os.rename(src, dst)
homeassistant | 2025-07-05T08:35:43.614690527Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.614705749Z OSError: [Errno 16] Resource busy: '/config/tmp0a9w5j8t' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:35:43.639838054Z 2025-07-05 10:35:43.615 ERROR (MainThread) [aiohttp.server] Error handling request from 82.65.149.132
homeassistant | 2025-07-05T08:35:43.639947607Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:35:43.639974422Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:35:43.639994514Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:35:43.640012940Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:35:43.640030106Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:35:43.640047180Z next(self.gen)
homeassistant | 2025-07-05T08:35:43.640062976Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640078568Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:35:43.640095679Z self.commit(f)
homeassistant | 2025-07-05T08:35:43.640111382Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:35:43.640126956Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:35:43.640143530Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:35:43.640158641Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640174363Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:35:43.640190881Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:35:43.640206455Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:35:43.640223732Z os.rename(src, dst)
homeassistant | 2025-07-05T08:35:43.640239010Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640254139Z OSError: [Errno 16] Resource busy: '/config/tmp0a9w5j8t' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:35:43.640299786Z
homeassistant | 2025-07-05T08:35:43.640318656Z The above exception was the direct cause of the following exception:
homeassistant | 2025-07-05T08:35:43.640335100Z
homeassistant | 2025-07-05T08:35:43.640350452Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:35:43.640365970Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
homeassistant | 2025-07-05T08:35:43.640382711Z resp = await request_handler(request)
homeassistant | 2025-07-05T08:35:43.640398488Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640414303Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
homeassistant | 2025-07-05T08:35:43.640430988Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640446395Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640461820Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
homeassistant | 2025-07-05T08:35:43.640478783Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640494338Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640509968Z File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
homeassistant | 2025-07-05T08:35:43.640528004Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640543560Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640568467Z File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
homeassistant | 2025-07-05T08:35:43.640587170Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640602892Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640618540Z File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
homeassistant | 2025-07-05T08:35:43.640635595Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640650724Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640666354Z File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
homeassistant | 2025-07-05T08:35:43.640683224Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640698520Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640714131Z File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
homeassistant | 2025-07-05T08:35:43.640885794Z return await handler(request)
homeassistant | 2025-07-05T08:35:43.640952386Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.640972663Z File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
homeassistant | 2025-07-05T08:35:43.640992366Z response = await handler(request)
homeassistant | 2025-07-05T08:35:43.641008310Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.641024606Z File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
homeassistant | 2025-07-05T08:35:43.641746390Z result = await handler(request, **request.match_info)
homeassistant | 2025-07-05T08:35:43.641771686Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.641789056Z File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
homeassistant | 2025-07-05T08:35:43.641806277Z return await func(self, request, *args, **kwargs)
homeassistant | 2025-07-05T08:35:43.641822222Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.641840962Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 134, in post
homeassistant | 2025-07-05T08:35:43.641858147Z await hass.async_add_executor_job(_write, path, current)
homeassistant | 2025-07-05T08:35:43.641874443Z File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
homeassistant | 2025-07-05T08:35:43.641891054Z result = self.fn(*self.args, **self.kwargs)
homeassistant | 2025-07-05T08:35:43.641908294Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 251, in _write
homeassistant | 2025-07-05T08:35:43.641925109Z write_utf8_file_atomic(path, contents)
homeassistant | 2025-07-05T08:35:43.641941164Z ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:35:43.641956812Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 42, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:35:43.641973774Z raise WriteError(error) from error
homeassistant | 2025-07-05T08:35:43.641989589Z homeassistant.util.file.WriteError: [Errno 16] Resource busy: '/config/tmp0a9w5j8t' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:37:09.321988661Z 2025-07-05 10:37:09.314 ERROR (SyncWorker_3) [homeassistant.util.file] Saving file failed: /config/automations.yaml
homeassistant | 2025-07-05T08:37:09.322166917Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:37:09.322207805Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:37:09.322242842Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:37:09.322275619Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:37:09.322311192Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:37:09.322344414Z next(self.gen)
homeassistant | 2025-07-05T08:37:09.322376043Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.322405950Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:37:09.322437857Z self.commit(f)
homeassistant | 2025-07-05T08:37:09.322467949Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:37:09.322498467Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:37:09.322531318Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:37:09.322562743Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.322593187Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:37:09.322716352Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:37:09.322910367Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:37:09.323090215Z os.rename(src, dst)
homeassistant | 2025-07-05T08:37:09.323117400Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.323212028Z OSError: [Errno 16] Resource busy: '/config/tmpmmm_1dzs' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:37:09.339523808Z 2025-07-05 10:37:09.322 ERROR (MainThread) [aiohttp.server] Error handling request from 82.65.149.132
homeassistant | 2025-07-05T08:37:09.339626232Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:37:09.339645473Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:37:09.339661250Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:37:09.339675713Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:37:09.339690083Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:37:09.339704675Z next(self.gen)
homeassistant | 2025-07-05T08:37:09.339718045Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.339732434Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:37:09.339747304Z self.commit(f)
homeassistant | 2025-07-05T08:37:09.339760933Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:37:09.339774507Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:37:09.339789192Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:37:09.339802951Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.339816821Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:37:09.339831488Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:37:09.339845395Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:37:09.339860320Z os.rename(src, dst)
homeassistant | 2025-07-05T08:37:09.339873765Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.339887190Z OSError: [Errno 16] Resource busy: '/config/tmpmmm_1dzs' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:37:09.339902023Z
homeassistant | 2025-07-05T08:37:09.339915542Z The above exception was the direct cause of the following exception:
homeassistant | 2025-07-05T08:37:09.339930023Z
homeassistant | 2025-07-05T08:37:09.339943134Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:37:09.339957356Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
homeassistant | 2025-07-05T08:37:09.339972337Z resp = await request_handler(request)
homeassistant | 2025-07-05T08:37:09.339986503Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340000911Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
homeassistant | 2025-07-05T08:37:09.340056854Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340076076Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340090427Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
homeassistant | 2025-07-05T08:37:09.340105223Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340120371Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340134038Z File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
homeassistant | 2025-07-05T08:37:09.340149093Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340162834Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340186037Z File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
homeassistant | 2025-07-05T08:37:09.340204074Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340218721Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340233017Z File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
homeassistant | 2025-07-05T08:37:09.340249091Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340263258Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340277591Z File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
homeassistant | 2025-07-05T08:37:09.340293257Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340307405Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340321590Z File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
homeassistant | 2025-07-05T08:37:09.340336534Z return await handler(request)
homeassistant | 2025-07-05T08:37:09.340350460Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340364682Z File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
homeassistant | 2025-07-05T08:37:09.340379774Z response = await handler(request)
homeassistant | 2025-07-05T08:37:09.340393496Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340407440Z File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
homeassistant | 2025-07-05T08:37:09.340422347Z result = await handler(request, **request.match_info)
homeassistant | 2025-07-05T08:37:09.340436366Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340450532Z File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
homeassistant | 2025-07-05T08:37:09.340465347Z return await func(self, request, *args, **kwargs)
homeassistant | 2025-07-05T08:37:09.340479476Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340493791Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 134, in post
homeassistant | 2025-07-05T08:37:09.340508994Z await hass.async_add_executor_job(_write, path, current)
homeassistant | 2025-07-05T08:37:09.340557123Z File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
homeassistant | 2025-07-05T08:37:09.340578141Z result = self.fn(*self.args, **self.kwargs)
homeassistant | 2025-07-05T08:37:09.340592530Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 251, in _write
homeassistant | 2025-07-05T08:37:09.340607270Z write_utf8_file_atomic(path, contents)
homeassistant | 2025-07-05T08:37:09.340621251Z ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:37:09.340636806Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 42, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:37:09.340652214Z raise WriteError(error) from error
homeassistant | 2025-07-05T08:37:09.340666380Z homeassistant.util.file.WriteError: [Errno 16] Resource busy: '/config/tmpmmm_1dzs' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:38:34.714960948Z 2025-07-05 10:38:34.707 ERROR (SyncWorker_3) [homeassistant.util.file] Saving file failed: /config/automations.yaml
homeassistant | 2025-07-05T08:38:34.715051890Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:38:34.715149778Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:38:34.715182203Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:38:34.715206073Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:38:34.715227887Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:38:34.715249368Z next(self.gen)
homeassistant | 2025-07-05T08:38:34.715270498Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.715290960Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:38:34.715312775Z self.commit(f)
homeassistant | 2025-07-05T08:38:34.715332367Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:38:34.715351922Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:38:34.715373255Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:38:34.715393273Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.715412884Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:38:34.715433772Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:38:34.715453754Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:38:34.715474364Z os.rename(src, dst)
homeassistant | 2025-07-05T08:38:34.715493697Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.715513197Z OSError: [Errno 16] Resource busy: '/config/tmp5tkjzs6j' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:38:34.736178010Z 2025-07-05 10:38:34.715 ERROR (MainThread) [aiohttp.server] Error handling request from 82.65.149.132
homeassistant | 2025-07-05T08:38:34.736269138Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:38:34.736294638Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 36, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:38:34.736338915Z with AtomicWriter(filename, mode=mode, overwrite=True).open() as fdesc:
homeassistant | 2025-07-05T08:38:34.736355526Z ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
homeassistant | 2025-07-05T08:38:34.736368544Z File "/usr/local/lib/python3.13/contextlib.py", line 148, in __exit__
homeassistant | 2025-07-05T08:38:34.736381581Z next(self.gen)
homeassistant | 2025-07-05T08:38:34.736394414Z ~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736406969Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 172, in _open
homeassistant | 2025-07-05T08:38:34.736420654Z self.commit(f)
homeassistant | 2025-07-05T08:38:34.736432950Z ~~~~~~~~~~~^^^
homeassistant | 2025-07-05T08:38:34.736445172Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 205, in commit
homeassistant | 2025-07-05T08:38:34.736458302Z replace_atomic(f.name, self._path)
homeassistant | 2025-07-05T08:38:34.736470227Z ~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736482468Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 99, in replace_atomic
homeassistant | 2025-07-05T08:38:34.736496060Z return _replace_atomic(src, dst)
homeassistant | 2025-07-05T08:38:34.736508375Z File "/usr/local/lib/python3.13/site-packages/atomicwrites/__init__.py", line 55, in _replace_atomic
homeassistant | 2025-07-05T08:38:34.736521560Z os.rename(src, dst)
homeassistant | 2025-07-05T08:38:34.736533356Z ~~~~~~~~~^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736545374Z OSError: [Errno 16] Resource busy: '/config/tmp5tkjzs6j' -> '/config/automations.yaml'
homeassistant | 2025-07-05T08:38:34.736558244Z
homeassistant | 2025-07-05T08:38:34.736569911Z The above exception was the direct cause of the following exception:
homeassistant | 2025-07-05T08:38:34.736582559Z
homeassistant | 2025-07-05T08:38:34.736594188Z Traceback (most recent call last):
homeassistant | 2025-07-05T08:38:34.736606799Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_protocol.py", line 510, in _handle_request
homeassistant | 2025-07-05T08:38:34.736619836Z resp = await request_handler(request)
homeassistant | 2025-07-05T08:38:34.736631854Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736643780Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_app.py", line 569, in _handle
homeassistant | 2025-07-05T08:38:34.736656520Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736668242Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736680187Z File "/usr/local/lib/python3.13/site-packages/aiohttp/web_middlewares.py", line 117, in impl
homeassistant | 2025-07-05T08:38:34.736693409Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736705242Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736717204Z File "/usr/src/homeassistant/homeassistant/components/http/security_filter.py", line 92, in security_filter_middleware
homeassistant | 2025-07-05T08:38:34.736730926Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736749204Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736789499Z File "/usr/src/homeassistant/homeassistant/components/http/forwarded.py", line 210, in forwarded_middleware
homeassistant | 2025-07-05T08:38:34.736806907Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736878961Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736894961Z File "/usr/src/homeassistant/homeassistant/components/http/request_context.py", line 26, in request_context_middleware
homeassistant | 2025-07-05T08:38:34.736908868Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736921256Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736933478Z File "/usr/src/homeassistant/homeassistant/components/http/ban.py", line 86, in ban_middleware
homeassistant | 2025-07-05T08:38:34.736946756Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736958959Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.736971052Z File "/usr/src/homeassistant/homeassistant/components/http/auth.py", line 242, in auth_middleware
homeassistant | 2025-07-05T08:38:34.736984348Z return await handler(request)
homeassistant | 2025-07-05T08:38:34.736997014Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.737009421Z File "/usr/src/homeassistant/homeassistant/components/http/headers.py", line 41, in headers_middleware
homeassistant | 2025-07-05T08:38:34.737023032Z response = await handler(request)
homeassistant | 2025-07-05T08:38:34.737035310Z ^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.737047717Z File "/usr/src/homeassistant/homeassistant/helpers/http.py", line 73, in handle
homeassistant | 2025-07-05T08:38:34.737060902Z result = await handler(request, **request.match_info)
homeassistant | 2025-07-05T08:38:34.737073680Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.737086087Z File "/usr/src/homeassistant/homeassistant/components/http/decorators.py", line 83, in with_admin
homeassistant | 2025-07-05T08:38:34.737099494Z return await func(self, request, *args, **kwargs)
homeassistant | 2025-07-05T08:38:34.737111716Z ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.737123956Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 134, in post
homeassistant | 2025-07-05T08:38:34.737136864Z await hass.async_add_executor_job(_write, path, current)
homeassistant | 2025-07-05T08:38:34.737149141Z File "/usr/local/lib/python3.13/concurrent/futures/thread.py", line 59, in run
homeassistant | 2025-07-05T08:38:34.737162067Z result = self.fn(*self.args, **self.kwargs)
homeassistant | 2025-07-05T08:38:34.737174418Z File "/usr/src/homeassistant/homeassistant/components/config/view.py", line 251, in _write
homeassistant | 2025-07-05T08:38:34.737187770Z write_utf8_file_atomic(path, contents)
homeassistant | 2025-07-05T08:38:34.737200085Z ~~~~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^
homeassistant | 2025-07-05T08:38:34.737212381Z File "/usr/src/homeassistant/homeassistant/util/file.py", line 42, in write_utf8_file_atomic
homeassistant | 2025-07-05T08:38:34.737225566Z raise WriteError(error) from error
homeassistant | 2025-07-05T08:38:34.737237677Z homeassistant.util.file.WriteError: [Errno 16] Resource busy: '/config/tmp5tkjzs6j' -> '/config/automations.yaml'
I’ve checked my yaml config under developer settings and HA says everything is fine, I’ve plenty of space on my config folder.
I’ve even given 777 permision to the file to rule out any rights error.
My configuration.yaml does include :
My automations.yaml is empty.
