Solved - Schlage BE469 missing node user code
I’ve just added a new Schlage BE469 ZWave lock and for some reason the Node user code section is missing in the ZWave control panel for it.
Added securely and it’s working fine.
I have another BE469 that I added a few years ago now and the Node user code section is there and I can set user codes fine.
Anyone else run into this? Running Supervisor 229/HassOS 4.11/Core .112.2
Edit: also notice there are several entities missing for it (power management, sourcenodid, burglar, system, access control) that are there for the other lock…something’s definitely wonky here…might have to try excluding and re-including.
Yep that’s what it was. Did an exclude/include and everything shows up now.
