[Solved] "Selection to subflow" is not there, nor the Subflow menu
Hey! I like to use Node-RED and right now I’m working on a custom logic for my shutters. I have many of them and I contemplate the perspective of doing lots of copy/paste and end-up with a big and messy flow for these shutters. While looking into alternative ways of doing it, I discovered the “subflow” notion, and the ability to select nodes, then convert them to a subflow. Only, that “selection to subflow” command seems to be missing from the latest Node-RED integration I have here. The Subflows menu in the navigation pane also shows no Subflows menu. Does anyone encoutered the same problem? Or, alternatively, would someone be able to direct me so I can enable the missing Subflows menu?
I can’t help with your issue, but I can confirm that the it works with v 13.3.0 of the add-on, which uses NR v3.0.1
Oh! Thanks for the screen capture. I’ve missed that menu. Now I also have it :smiley:
