[SOLVED] Set LED on_state trigger
Hi
I want to set 2 LED’s to a colour each the colour is changed (2 LED’s will always be 1 colour)
Here’s what I have:
esphome:
esp8266:
  board: esp01_1m
  framework:
    version: 2.7.4
wifi:
  ssid: !secret wifi_ssid
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
light:
  - platform: fastled_clockless
    chipset: WS2812
    pin: 2
    num_leds: 30
    rgb_order: GRB
    on_state:
      lambda: |-
        it[28] = Color(255,255,255);
        it[29] = Color(255,255,255);
    effects:
    - addressable_lambda:
        name: "Pacman Green with White Eyes"
        update_interval: 16ms
        lambda: |-
          it.range(0, 28) = Color(0,255,0);
I can use an effect to get the desired output but I don’t really want to have to create x number of effects just so I can select some colours.
I receive an error when compiling:
INFO Reading configuration /config/esphome/pacman.yaml...
WARNING The selected Arduino framework version is not the recommended one. If there are connectivity or build issues please remove the manual version.
INFO Generating C++ source...
INFO Compiling app...
Processing pacman (board: esp01_1m; framework: arduino; platform: platformio/espressif8266 @ 2.6.3)
HARDWARE: ESP8266 80MHz, 80KB RAM, 1MB Flash
LDF: Library Dependency Finder -> https://bit.ly/configure-pio-ldf
Dependency Graph
|-- <ESP8266WiFi> 1.0
|-- <ESP8266mDNS> 1.2
|-- <FastLED> 3.3.2
Compiling /data/pacman/.pioenvs/pacman/src/main.cpp.o
/config/esphome/pacman.yaml: In lambda function:
/config/esphome/pacman.yaml:30:7: error: 'it' was not declared in this scope
At global scope:
cc1plus: warning: unrecognized command line option "-Wno-nonnull-compare" [enabled by default]
*** [/data/pacman/.pioenvs/pacman/src/main.cpp.o] Error 1
========================== [FAILED] Took 4.05 seconds ==========================
Is there any way to do this?
For anyone wondering I managed to achieve this but using the addressable_set action
esphome:
esp8266:
  board: esp01_1m
  framework:
    version: 2.7.4
wifi:
# Enable logging
logger:
api:
ota:
light:
    chipset: WS2812
    pin: 2
    num_leds: 30
    default_transition_length: 0s
    rgb_order: GRB
    on_state:
      - delay: 100ms
      - light.addressable_set:
          range_from: 28
          range_to: 30
          red: 100%
          green: 100%
          blue: 100%
