[solved] Shell_command
Using HASSIO 0.73.2
configuration.yaml
shell_command:
  • frontdoor_photo: touch /share/shell-command-is-working.txt
I call the service and get log
Unable to find service shell_command/frontdoor_photo
Ideas?
It is listed under services inside developer tools
restarted the all thing and works now
I twisted my head for the same thing…
Stupid that a simple reload of config does not work for new shell_command entries.
This could be a bug maybe?
If you edit config yaml you MUST restart HA… only way
It seems kind of odd, since I considered “Reload core” = reload configuration.yaml
I’ll just restart the bastard in the future to ensure everything is updated.
it’s a common confusion for sure. There is some king of explanation of what reload core does. I’ll see if I can find it…
OK
reload core only reloads things under homeassistant: in your config.yaml so for instance customize stuff. Note not everything in config yaml is under the homeassistant: first level…
