SOLVED: Template error ?syntax
Hi all,
I need to ask for your help again. I cannot figure out why this will not evaluate correctly. I’m assuming this may be a syntax issue but I can’t spot it. Please help my sanity.
{% set action_response = {"calendar.david_work":{"events":[{"start":"2026-01-21T16:00:00+00:00","end":"2026-01-21T23:45:00+00:00","summary":"4-Mid"},{"start":"2026-01-23T16:00:00+00:00","end":"2026-01-23T23:45:00+00:00","summary":"4-Mid"}]}} %}
{% set test = action_response["calendar.david_work"]["events"][0].start | as_datetime %}
{% set shift_start_hour = test.strftime('%H')|int %}
{% if shift_start_hour > 05 %}
Test
{% else %}
Error
{% endif %}
Instead of returning Test, I am instead getting the following error:
TemplateSyntaxError: expected token ‘end of statement block’, got ‘integer’
How can I get this if statement to work? Many thanks for any help you can provide.
I don’t understand why you are using curly brackets here. I would have these all regular parenthesis…
Also I would be plugging this in piece by piece into the developer panel to see what works.
Open your Home Assistant instance and show your template developer tools.
Leading zeroes for integers aren’t permitted in Python, so I assume they’re also not permitted in Jinja templates:
{% if shift_start_hour > 5 %}
You ask a great question. I’m not sure either and will change them.
I have been using the Template tab in the Developer tools section but appreciate you flagging it up in case I hadn’t been.
EDIT:
Oh, correction, I didn’t realise which part of the code you were commenting on. This is raw output copied from the “Calendar: Get Events” action and I believe is structured as JSON, so not my choice!
This. It was this. Thank you, just couldn’t see it!
