[SOLVED] Upgraded to AppDaemon 3, starts with no errors but not connecting to HA or loading apps
I moved my apps.yaml into /apps, modified the import and super class for all apps and updated my appdaemon.yaml
appdaemon.yaml
log:
  accessfile: /config/logs/access.log
  errorfile: /config/logs/error.log
  logfile: /config/appdaemon.log
  log_generations: 3
  log_size: 1000000
appdaemon:
  threads: 10
  time_zone: Australia/Sydney
  api_port: 5555
  api_key: !secret api_key
  plugins:
    HASS:
      type: hass
      ha_url: http://hassio/homeassistant
      ha_key: !secret hass_key
Log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 00-banner.sh: executing...
 Hass.io Add-on: AppDaemon3 v1.0.0
 Python Apps and HADashboard using AppDaemon 3.x for Home Assistant
 By: Franck Nijhof <[email protected]>
[cont-init.d] 00-banner.sh: exited 0.
[cont-init.d] 01-log-level.sh: executing...
Log level is set to INFO
[cont-init.d] 01-log-level.sh: exited 0.
[cont-init.d] 02-updates.sh: executing...
[cont-init.d] 02-updates.sh: exited 0.
[cont-init.d] 03-version-requirements.sh: executing...
[cont-init.d] 03-version-requirements.sh: exited 0.
[cont-init.d] 20-init-configuration.sh: executing...
[cont-init.d] 20-init-configuration.sh: exited 0.
[cont-init.d] 21-compiled-dir.sh: executing...
[cont-init.d] 21-compiled-dir.sh: exited 0.
[cont-init.d] 30-auto-password.sh: executing...
[cont-init.d] 30-auto-password.sh: exited 0.
[cont-init.d] 31-ha-url.sh: executing...
[cont-init.d] 31-ha-url.sh: exited 0.
[cont-init.d] 50-compiled-symlink.sh: executing...
[cont-init.d] 50-compiled-symlink.sh: exited 0.
[cont-init.d] 80-system-packages.sh: executing...
[cont-init.d] 80-system-packages.sh: exited 0.
[cont-init.d] 81-python-packages.sh: executing...
[cont-init.d] 81-python-packages.sh: exited 0.
[cont-init.d] done.
[services.d] starting services
[services.d] done.
That’s just the addon log - can you post the AppDaemon log please?
Have you tried using the IP address & port instead of the hassio/homeassistant part?
Sorry all, false alarm. It’s actually up and running normally - it’s just that I was used to having the logfile appear in STDOUT, which changed with v3, and I wasn’t getting any updates in my logs because I was having trouble setting up the directories correctly.
All figured out now :slight_smile: thanks for the update!
