Hi. I’ve been adding some of my zigbee sensors through the Sonoff integration (I have a Sonoff Zigbe Bridge Pro) and had a bad experience with it so I decided to delete the devices and flash Tasmota to the hub.
Now I’m configuring the sensors over ZHA and I want to edit the entity IDs and set them with the same IDs they had when being connected through the Sonoff bridge.
I found that the devices didn’t disappear from the Sonoff integration (they disappeared from the eWelink app but not from HA even after refreshing the integration or restarting HASS).
So I went and edited the names and entity IDs of the old devices so I could set these IDs to the ZHA devices.
This worked fine for a minute but after a restart these devices appeared again in this form:
And in the “Related” tab it says “No related items found.”
I checked all the devices in the Sonoff integrations and none of them are showing with these entity IDs (because I edited them and then disabled them).
What can I do to get rid of these ghost devices?
Thanks,
Rodrigo
