I just installed Hassio.io on an Ubuntu Sever. Node-Red add on and Check Configuration add on won’t stay running. What do I need to do? Thanks
Refresh the add-on’s logs (found at bottom of add-on’s page) to see what error messages are appearing that is preventing the add-on from running properly. There may be a configuration you need to update before running the add-on.
