Hi everyone, I recently switched from my Tuya Zigbee gateway to Home Assistant using Zigbee2mtq.
I’m currently having some issues with a few sensors and hope there’s a solution.
Some sensors that had access to many more entities when used with the Tuya Zigbee Gateway are not available via zigbee2mqtt. In particular, the adjustable “keep time” setting is no longer available for these sensors. These include, among others, the following sensors:
PIR1-ZB no keep time available any more PIR1-ZB. The sensor is shown as TS0202 (_TZ3040_wqmtjsyk)
Luminea ZX-5231-675 (maybe device id changed recently) https://www.pearl.de/a-ZX5231-3111.shtml -->no keep time available anymore. Device is shown as TS0202 (_TZ3000_mnlsbthu)
The PIR1-ZB I could find in the Zigbee2Mqtt data base, but not the luminea. What options are available for making the entities (mainly “keep time”) available again?
I also have another issue with an LIDL LED Lamp: LIDL 14148906L / TS0505A (is in database) which is shown as TS0505A (_TZ3000_9cpuaca6). With this one, I can no longer adjust the colors, even though the option is available in the settings.
Is there perhaps a solution for these issues (missing entities and incorrect controls [color settings])?
Thanks for your help!
