Some issues with my first script
Let me first outline the situation and tell you that I’m rather new to HA. I have 5 Sonos devices where I want to select some to join them and send a broadcast message to. This broadcast message is an attention sound (mp3) and a text to speech message after the attention. After this is played the grouped Sonos devices should unjoin, and if they were playing some music, continue to play music.
I encounter several issues in my script (the script is executed by pressing a button card)
  1. The script only runs once
  2. The text to speech message does not play (that piece of code is working when running on its own)
  3. The sonos speakers are not unjoined
  4. Is it possible to have no master Sonos or just use the first one from the array {{ players[0] }}
Could someone please point me in the right direction, I think there is something wrong with the wait trigger, but if I’m not using it the mp3 is not played till the end. I also think the text to speech could not handle grouped devices.
testcombine:
  alias: testCombine
  sequence:
  - variables:
      players: >
        {{ [] + (['media_player.badkamer'] if is_state('input_boolean.bsonosbadkamer', 'on') else []) +
          (['media_player.studeerkamer'] if is_state('input_boolean.bsonosstudeerkamer', 'on') else []) +
          (['media_player.sonoskeuken'] if is_state('input_boolean.bsonoskeuken', 'on') else []) +
          (['media_player.draagbaar'] if is_state('input_boolean.bsonosdraagbaar', 'on') else []) +
          (['media_player.woonkamer_2'] if is_state('input_boolean.bsonosliving', 'on') else []) }}
  - condition: "{{ players | count > 0 }}"
# save state and join
  - service: sonos.snapshot
    data_template:
      entity_id: "{{ players }}"
  - service: media_player.join
      group_members: "{{ players }}"
      entity_id: media_player.draagbaar
# set volume
  - service: media_player.volume_set
    data_template:
      volume_level: '0.10'
# play attetion sound
  - service: media_player.play_media
    data_template:
      entity_id: '{{ players }}'
      media_content_id: 'http://192.168.0.221:8123/local/Airport.mp3'
      media_content_type: music
# added this trigger otherwise it doesn't play the whole mp3
  - wait_for_trigger:
      - platform: state
        entity_id: media_player.draagbaar #could not use the players array here or the first one?
        to: idle
# text to speech message - not executed works on its own
  - service: tts.google_say
    data_template:
      message: 'This is a test to check if the grouping is working'
# wait 5 seconds to ungroup
  - delay: 00:00:05
# unjoin and go to orioginal state - not executed/working
  - service: media_player.unjoin
  - service: sonos.restore
    data_template:
  mode: single
Issue 1 and 2 are solved by changing to paused instead of idle in the wait_for_trigger. The only problem I have is that the unjoin is still not working. This is strange because I can see it a lot in different examples.
