Some theme help
Can anyone help with the code for changing color for a little blue dot?
web_clip_1
I’d like this little blue dot to change color to red. But what do I need to add to my theme CSS?
/Brygger
add a line
  accent-color: "#FF0000"
to your theme
Followed your recommendation but unfortunately not the solution. But thanks for the reply anyway :sunglasses:
/Brygger
weird, because I tried it again, and it still works.
MTA: This assumes you’re not using the default theme. You have to use another theme in order for the accent color to change.
I am using a custom theme grabbed from someone else here :sunglasses:
The thing is that when I change to your suggestion, it also changes color of all the toggle buttons and a few other places. I didn’t want that, only for this little annotation dot. That way it’s easier to notice when a message is present in the pop-out menu.
Trouble is all those things are part of the accent color.
This should work for notification dot
accent-color: ‘#E45E65
Thanks for info Jim. I must accept the fact that it can’t be done then :frowning:
Your answer will be the final for my little quest to spice up the frontend.
/Brygger
Is this serious? Did my post not make sense? I r confuzed.
Yes your post made sense just clarifying remarks made after your post. :+1:
