The Code Editor did not work for me in any WebKit-based browsers in 2023.3.x. This includes Safari, and also the iOS / Mac Companion app.
203.4.4 fixes this, and I can again view and edit using the Code Editor, BUT… I’ve found two possible bugs:
In the companion app, if I switch to a code editor, and select the contents (either manually or with Command-A), the contents can’t be copied. If you choose the Edit → Copy command, nothing is actually placed on the clipboard. Same for Command-C. Lastly, if you try to right-click the selection, the selection becomes deselected.
In Safari (the latest at time of writing, OS 13.3.1, Safari 16.4), the contents CAN be copied, but when pasted into a text editor, there are no line breaks:
P.S. All of this behaves as expected in Firefox, which is my current workaround.
