ukro
June 5, 2021, 11:23am
1
2021-06-05 00:03:18 WARNING (MainThread) [homeassistant.components.http.ban] Login attempt or request with invalid authentication from supervisor (172.30.32.2). (Python/3.9 aiohttp/3.7.4.post0)
The subnet is not in any of my networks.
What is going on?!
Are you sure it is not a network created by docker?
That subnet is in the private range which means it could not come from the Internet. Some ISPs use customer facing private networks internally though.
ukro
June 5, 2021, 11:43am
3
Thank you for reply.
Yeah i didn’t realise.
And the invalid authentication from supervisor.
So its some plugin etc?
Just in case will update all addons
Searching found you could tun this command, as root, to list the containers & ip addresses.
docker ps -q | xargs -n 1 docker inspect --format '{{ .Name }} {{range .NetworkSettings.Networks}} {{.IPAddress}}{{end}}' | sed 's#^/##';
Here is my output as an example.
homeassistant
hassio_observer 172.30.32.6
addon_core_configurator 172.30.33.0
hassio_multicast
hassio_cli 172.30.32.5
hassio_audio 172.30.32.4
hassio_dns 172.30.32.3
zwavejs2mqtt 172.17.0.2
hassio_supervisor 172.17.0.3 172.30.32.2
On my system this command indicates that ts the range used by Home Assistant.
ip addr | grep 172
inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
inet 172.30.32.1/23 brd 172.30.33.255 scope global hassio
ukro
June 5, 2021, 1:09pm
5
Thank you for commands,
But obviously its supervisor, the dns sais. But what the hell supervisor want to login?..
