[workaround] Somfy cover with RFXtrx not working
as per RFXCOM RFXtrx - Home Assistant I programmed my Somfy to work with RFXmngr.
ID: 5 55 55
Unit Code: 2
RFXtrx works fine in HA as I get some t° data from the neighbours.
That’s what I get in the logs when I hit the [stop] button which should put the shutter to preset position. But UP/Down do’nt work neither:
2017-09-08 17:35:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event call_service[L]: domain=cover, service=stop_cover, service_data=entity_id=cover.stores_electriques, service_call_id=1960908880-17>
2017-09-08 17:35:04 DEBUG (MainThread) [homeassistant.components.websocket_api] WS 1930919568: Sending {'id': 51, 'type': 'event', 'event': {'event_type': 'call_service', 'data': {'domain': 'cover', 'service': 'stop_cover', 'service_data': {'entity_id': 'cover.stores_electriques'}, 'service_call_id': '1960908880-17'}, 'origin': 'LOCAL', 'time_fired': datetime.datetime(2017, 9, 8, 15, 35, 4, 542510, tzinfo=<UTC>)}}
Send: 0x08 0x1a 0x00 0x02 0x05 0x55 0x55 0x02 0x00
2017-09-08 17:35:04 INFO (MainThread) [homeassistant.core] Bus:Handling <Event service_executed[L]: service_call_id=1960908880-17>
And this is my config :
cover:
  - platform: rfxtrx
    automatic_add: False
    signal_repetitions: 1
    devices:
      071a000005555502: # RFY
        name: Stores éléctriques
Has someone any idea what could be wrong?
If you have a working setup can you share your settings and logs?
seems that my device ID is correct as it doesn’t appear in the devices when I alter it.
Does anyone has an idea how to debug this further?
have you ever found out how this works? according to this thread, your code is missing trailing zeros.
071a0000 0555550 2
09190603 0A0A0AA 1 00 00
09190603 [id] [unit_code] [cmd] 00
resulting in that code, this should work:
cover:
  - platform: rfxtrx
    automatic_add: false
    signal_repetitions: 8
    devices:
      071a0000055555020000:
Hi ,
Thanks for pointing to this, I’ll check, but actually I bought an RFLink set which worked out of the box^^^solder iron and since then my blinds go up and down with the sun’s elevation.
BRB reprogramming the RFXtrx.
having both, a rfxtrx and a rflink is a good solution, that i also chose :slight_smile:
I know this is a very old post but who knows, maybe this might help someone struggling with RFXtrx and Somfy covers.
As my rflink stopped working a couple of weeks ago, I took the time to try to get the RFXtrx device to work with my blinds.
I added the integration again with event code 071a0000020F0F02.
Packettype    = RFY
subtype       = RFY
Sequence nbr  = 13
id1-3         = 020F0F decimal:134927
Unit          = 2
Command       = stop
rfu1          = 00
rfu2          = 00
rfu3          = 00
Signal level  = +10 dBm
That worked and I get a buton for down, stop and up. But still nothing moves from there.
That’s from the HA logs when I push down, stop and up:
2023-10-15 14:16:17.191 DEBUG (SyncWorker_0) [RFXtrx] Send: 0x0c 0x1a 0x00 0x03 0x0f 0x0f 0x0f 0x01 0x11 0x00 0x00 0x00 0x00
2023-10-15 14:16:17.261 DEBUG (Thread-10 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x01 0x03 0x0f 0x53 0x16 0x28 0x00 0x67 0x00 0x01 0x03 0x1c 0x04 0x00 0x00 0x00 0x00 0x00 0x00
2023-10-15 14:17:25.584 DEBUG (SyncWorker_3) [RFXtrx] Send: 0x0c 0x1a 0x00 0x04 0x0f 0x0f 0x0f 0x01 0x00 0x00 0x00 0x00 0x00
2023-10-15 14:17:25.801 DEBUG (Thread-10 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x01 0x04 0x0f 0x53 0x16 0x28 0x00 0x67 0x00 0x01 0x03 0x1c 0x04 0x00 0x00 0x00 0x00 0x00 0x00
2023-10-15 14:17:28.591 DEBUG (SyncWorker_9) [RFXtrx] Send: 0x0c 0x1a 0x00 0x00 0x0f 0x0f 0x0f 0x01 0x12 0x00 0x00 0x00 0x00
2023-10-15 14:17:28.663 DEBUG (Thread-10 (_connect)) [RFXtrx] Recv: 0x14 0x01 0x01 0x00 0x0f 0x53 0x16 0x28 0x00 0x67 0x00 0x01 0x03 0x1c 0x04 0x00 0x00 0x00 0x00 0x00 0x00
That’s what I get form the RFXmngr when I transmit Down, Stop/My, Up:
15-10-23 02:20:51:169= 1401071107436F7079726967687420524658434F4D
15-10-23 02:20:55:274= RFY command: 0C 1A 00 12 02 0F 0F 02 03 00 00 00 00
Packettype    = RFY
subtype       = RFY
Sequence nbr  = 18
Unit          = 2
Command       = down
rfu1          = 00
rfu2          = 00
rfu3          = 00
15-10-23 02:20:55:873= 0402011200
Packettype        = Receiver/Transmitter Message
subtype           = Transmitter Response
Sequence nbr      = 18
response          = ACK, data correct transmitted
15-10-23 02:21:00:392= RFY command: 0C 1A 00 13 02 0F 0F 02 00 00 00 00 00
Packettype    = RFY
subtype       = RFY
Sequence nbr  = 19
Unit          = 2
Command       = stop
rfu1          = 00
rfu2          = 00
rfu3          = 00
15-10-23 02:21:01:129= 0402011300
Sequence nbr      = 19
15-10-23 02:21:04:507= RFY command: 0C 1A 00 14 02 0F 0F 02 01 00 00 00 00
Packettype    = RFY
subtype       = RFY
Sequence nbr  = 20
Unit          = 2
Command       = up
rfu1          = 00
rfu2          = 00
rfu3          = 00
15-10-23 02:21:05:061= 0402011400
Sequence nbr      = 20
So the commands sent from HA don’t correspond. So I tried to use the service rfxtrx.send to send those commands
#down
service: rfxtrx.send
  event: "0C 1A 00 12 02 0F 0F 02 03 00 00 00 00"
#stop
  event: "0C 1A 00 13 02 0F 0F 02 00 00 00 00 00"
#up
  event: "0C 1A 00 14 02 0F 0F 02 01 00 00 00 00"
And this worked. I can know use this for my automations. I don’t have a nice cover panel but that’s a minor problem as I’m happy to get the blinds automated again (and that I can use the RFXtrx module after 5 years of taking dust).
