Somfy hub (if using Somfy Connexoon IO - do i need a remote?)
i have many HA integrations, but buying new shades got me to require Somfy.
Based on remote they are proposing (https://www.somfy.co.uk/products/1870329/situo-5-io-pure-ii) seems that the Somfy standard would be IO (and not RTS).
What is the minimum i need to integrate this into HA?
-most expensive is Tahoma (https://shop.somfy.de/tahoma-premium.html)
-is Somfy Connexoon IO enough (https://shop.somfy.de/smart-home/einstieg-in-smart-home/connexoon-io-steuerung.html)
Does anyone have experience with Somfy? I wonder if i even need the remote if i buy directly Somfy Connexoon IO hub?
Cheers
Hi @nymare,
Did you manage to get to a conclusion? I have some window shutters from somfy that i would like to integrate in home assistant.
Are your devices IO or RTS? You could use a Connexoon or TaHoma bridge for IO + RTS, or even a Velux KFL200 for IO if you want local control.
